Results 1 to 10 of 16
Thread: 2 bar set up on a 99 k1500
    Sep 2007
    Default 2 bar set up on a 99 k1500
    with a 5.3L, current OS is 09379910... I would like to upgrade with minimal heartache to COS5, but need to retain auto trans and 4wd items... Truck has no MAF and 2 bar map sensor, switching from HPT
    what do I do?
    If a 4WD 12212156 OS with the same transmission will run on your PCM then that is what you need to start from.
    First you will have to use EFILive to read the tune from the PCM and save it to file.
    Then You would have to first copy all your tables (including transmission tables) into a copy of 12212156 (open two instances of the tunetool, copy table-by-table from the 09379910 file to 12212156 file, take your time, it will take a few hours, there's no other way, be sure to save the 12212156 file when finished copying).
    Then you can full flash the 12212156 file into your PCM and your vehicle should run the same.
    Sep 2007
    do you have a file i can start from?
    Sep 2007
    I have a 2156 file, but I tried to do a full flash and it will reject it...?
    Then that OS won't go into that PCM.
    Sep 2007
    any other thoughts? different pcm? flash this one with tech II to that other vin?
    When you tried to do a full flash of 12212156 into your PCM, what was printed out in the text box, can you paste it here...
    For a 99 truck, that means Vortec Black Box PCM. You need to upgrade to an 0411 and then do the OS flash/2Bar update.
    Sep 2007
    This is a ls style pcm...
    I do NOT have a 2156 to start from, my dyslexia must have been kicking in... Any help with that?
    Sep 2007
    I have an 8322 but that has a 4l80e, can i swap trans segment?
  1. COS 3.3 bar map only reading 2.5 bar
    By BAD BOB in forum FlashScan V2
    Last Post: August 8th, 2011, 12:27 PM
  2. 1998 k1500 5.0 305
    By JustinD in forum Vortec V6/V8 Specific
    Last Post: May 28th, 2010, 03:03 AM
  3. 3 Bar MAP sensor doesn't work with 3 Bar scaling!
    Last Post: April 27th, 2010, 05:21 PM
  4. Best Way to Set up 98 for 2 bar MAP
    By CTP Racing in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 8th, 2006, 11:17 AM
  5. Custom 3 bar open loop O.S.... can I run closed for 1 bar?
    Last Post: September 7th, 2005, 09:21 PM
