Results 1 to 2 of 2
Thread: No response idle issue please help!
    Mar 2008
    Default No response idle issue please help!
    I am tuning a 2008 silverado w/E38. It has a supercharged 408 CID built engine (stock throttle body, 227/236 cam). I've tuned about 18 E38 PCM's but have never had this problem. I've read the sticky tutorials and followed them exactally with great success on other cars. (Thanks for the tutorials!) Here's the problem. No matter what I set the tables and parameters to, the idle stays the same. I've maxed the idle airflow and went from 2% to 90% on the max idle throttle position and everywhere in between. Sorry I can't list the table numbers because I don't have my tuning computer with me right now. I can't get the TP with idle included to go over 2.2%. I'm tuning a 2010 Camaro right now and made all the same adustments and it turned out perfectly! I should also tell you that both of these vehicles are mafless. Please help!
    Mar 2008
    Anyone?
  1. Idle Issue
    By NosubstituteforCI in forum Gen III V8 Specific
    Last Post: March 17th, 2011, 06:16 PM
  2. 2010 Camaro idle no response
    By SPi in forum E37, E38 & E67 PFI ECM's
    Last Post: March 8th, 2011, 03:16 PM
  3. Idle issue
    By Harrismarine in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2008, 06:27 PM
  4. Idle issue
    By Jakes4321 in forum Gen III V8 Specific
    Last Post: January 7th, 2008, 12:49 PM
  5. Low (but stable) idle, bad response when cold ...
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: August 29th, 2006, 01:03 PM
