sorry if this is in the wrong place
ok, so a friend at work drives a 2008 chevy silverado 1500 4.8L crewcab
right now he clams that it gets 13 MPG max. even on the highway. it was supposed to get 14 city and 19 on the highway
he has taken it in the dealer several times. they have't found anything. says nothing is wrong. even loaded the latest updates from GM. still the MPG is 13 city and highway. as far as i know everything is stock.
recently he filled up on mid grade gas 93 octane. the MPGs went from 13 up to 16.75. this is all based on fill ups and odometer. none of this dash stuff. this is the third time he tried this and the results are the same.
now i know the engine was designed to run on low octane so what the deal here? i remember reading somewhere that if the engine gets better MPGs on higher octane fuel then something is wrong with the engine, Knock sensor?, baro or temp?
anyone have any ideas what to look for?
i know some of you are going to tell me that the slower burning higher octane gas will always get you better MPGs do to being able to advance the timing. what i am after is that the truck only gets 13 everywhere and the mid grade brings it back to where it is supposed to be.
anyone have any ideas what to look for? trying to help him out
Thanks Jason
