Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Better MPG with higher octane = something is wrong with engine???
  1. #11
    No, they will not throw any codes, their response has slowed down, but it is still within the PCM's test limits (older cars had looser limits).
  2. #12
    Lifetime Member LB72004's Avatar
    Dec 2011
    Bingo, that just might be it. i guess i would have to monitor the voltage/reading on them and see what i get. any clue what i would be looking for? or is it just better to replace them?
    if i remember right, he has something like 120 or 130 something thousand miles on it now. he was also talking about replacing the plugs for the first time. if that was the reason then it wouldn't explain the bad mileage when it was driven off the dealer lot.
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
  3. #13
    If the NBO2's have 70K+ miles on them they usually are worn out.
    I would also change the plugs much earlier, maybe every 50K miles.
  1. L92 stroker engine won't run higher than about 3800rpm
    By whypave in forum Gen IV V8 Specific
    Last Post: August 23rd, 2011, 06:14 AM
  2. Sparks Higher than we are asking
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: April 22nd, 2010, 07:02 AM
  3. What happens when I set a value higher than the tables know?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 1st, 2009, 02:32 AM
  4. more air = higher compression?
    By jchev502 in forum Vortec V6/V8 Specific
    Last Post: July 19th, 2008, 09:21 AM
  5. Replies: 2
    Last Post: August 7th, 2005, 03:04 PM
