Results 1 to 6 of 6
Thread: Vortec 454 swap
    Oct 2007
    Default Vortec 454 swap
    i have swapped a 454 vortec into my 1997 4l60e reg cab silverado
    Things i swapped were 454 harness and black box from a 98 ck3500
    the problem is that when i run my 97 blackbox the truck shifts fine but it missfires, its due to the 97 5.7 computer.
    when i run my 98 computer it idles fine but it .feels sluggish problably due that the harness is for a 4l80e tranny.
    what i find wierd is that the truck shifts fine with a 5.7 60e computer under the 454 harness???
    i know i cant do a segment swap in these pcms, would it be easier just to swap my 60e for a 80e? i would really like to run a 60e.
    Heres my 454 tune...
    Aug 2010
    Try this one ... I don't tune Vortec PCMs so no guarantee it will work ... you will need to enter your gear ratio and tire diameter information, and then adjust the shift / TCC speeds ....
    Regards,
    Taz
    EDIT: You will also need to rewire the transmission plug from your 1998 4L80 harness, to that of a 4L60 - move one wire, and add two new wires.
    Id probably just upgrade to a LS1B 0411 PCM and go from there, yes its another $200 (75-100 for PCM, 125 for VIN license) but would be worth it IMO.
    Let us know how the file Taz posted works.
    Oct 2007
    i cant find a diagram on what wires to change at the trans connector. i have done 4l80e conversions on lsx trucks, dont know if this is different.
    Aug 2010
    Quote Originally Posted by blazinblue View Post
    i cant find a diagram on what wires to change at the trans connector. i have done 4l80e conversions on lsx trucks, don't know if this is different.
    You will need a good GM Service Manual (Helm Inc. sells manuals used by the OEM) for a 1998 Truck - one that covers 5.7 L and 8.1 L engines / transmissions. A good manual(s) is something that should be invested in prior to beginning a conversion, rather than after something doesn't work correctly.
    Attached is a PDF that depicts the global difference in the transmission connectors (4L60 vs 4L80) - but does not include the pinouts for the Vortec PCM (don't have them - don't work with that PCM).
    Regards,
    Taz
    Lifetime Member schwoch1's Avatar
    Jan 2009
    I second the 0411 swap, in the long run you will be money ahead!!! Fairly easy to do, and leaves plenty of room for improvement in the future!!! Also, like TAZ said, make sure you pin the transmission connector correctly, would be the same with the LSX truck from 60 to 80 swap. You can also switch them at the PCM if you want to not mes with the connector on the transmission.
    Good Luck
    Mike
    Current toys are as follows:
    1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
    1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
    1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
    1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
    1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
  1. 0411 swap on 99 Vortec 454
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 22nd, 2013, 12:49 PM
  2. vortec v6 to vortec v8 swap
    By grezzmky in forum Vortec V6/V8 Specific
    Last Post: September 21st, 2009, 06:49 AM
  3. 98 Vortec 454
    By knagel in forum Vortec V6/V8 Specific
    Last Post: October 7th, 2008, 02:21 PM
  4. Vortec 454 CMPRET?
    By N0DIH in forum Gen III V8 Specific
    Last Post: September 2nd, 2008, 08:27 AM
  5. Vortec 350/454 98-99 PIDs?
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: March 22nd, 2008, 06:30 AM
