Results 1 to 10 of 14
Thread: How to make a 50hp tune?
    Jan 2006
    Default How to make a 50hp tune?
    Hi i was wondering since the maximum additional hp on a stock allison transmission is 65hp, has anyone figured out how to make a modurate 50hp LB7 tune? I tried the 100hp tune and it was amazing and all (great low end boost) but i am really worried about transmission damage. Thanks for anyones help... I tried making my own tune by halving the 100 hp fuel and boost numbers but i am not sure that that is the proper mixture. Does anyone know if there are any ill effects of raising the rev limiter to 4000 rpm?
    -Rob
    Jan 2006
    anyone have any suggestions?
    New Member HD-Nate's Avatar
    Feb 2006
    Not into the EFI.......yet, but I have the 125 hp tune on my Edge Hot Juice box.
    I run it in the 100 hp range for my daily driving and the 125 range for the occassional need for speed.
    I let my tranny learn slowly, 100 miles at each level, starting at level 1 then up to 5.
    It has never limped on me and I have close to 70,000 mile on it from new.
    Senior Member lakingslayer's Avatar
    Dec 2005
    I haven't started dynoing my tunes yet. I do know what I have is at least 80hp. Chirps the tires when the TC locks under heavy throttle.
    Dec 2005
    Quote Originally Posted by gto4evr
    Rob
    Try starting with these 4 tables to make your first changes. You can set a custom PID and monitor the information so you know what changes need to be made and where in the calibration tables. You will need to do several different kind of test runs and use that data to make the changes. That's a start.
    Engine Calibration.Fuel Injection.Quantity
    {B0720} Main Injection Pulse, modified.
    {B0721} Main Injection Pulse (No Pilot), modified.
    {B0727} Throttle Base Injection Quantity, modified.
    Engine Calibration.Fuel Injection.Timing
    {B0910} Injection Timing (C), modified.
    Is this what your look-in for?
    Jan 2006
    yes that was what i was looking for, but my only question is how far would you adjust those tables and still have the truck be a daily driver. I loved having the low end torque of the 100 hp tune, but my fuel economy obviously suffered. Is there any happy medium that you guys know of?
    -Rob
    Senior Member Wasted Income's Avatar
    Dec 2005
    The ONLY reason your fuel economy suffered with that 100 hp tune, was because you had a heavy foot. How else would you know how much you liked the low end power??
    The biggest factor to the milage you get is YOU. A 100 hp tune, should not negatively effect fuel economy on the highway, unless you're like me and you stand on it all the time, just for fun
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Jan 2006
    ok yeah i agree, the power is intoxicating... my only issue is that i don't want to have the transmission shifting so oddly- and at the wrong points. This truck is in for the long haul as i don't have like 6 grand to replace the trans. I reguards to fuel economy, yeah i guess it was me- but cmon how often do you get to go to 115MPH in a diesel truck?
    -Rob
    Lifetime Member bobo's Avatar
    Nov 2005
    -Rob
    Once a week at least!!
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Just compare the level of difference between a stock file and the 100Hp tune (boost table and main fuel pulse tables) then compromise somwhere in between. Of course without a dyno you can't verify the actual power difference.
  1. Need help to make big tune
    By farmer in forum Duramax LB7
    Last Post: February 23rd, 2009, 09:15 AM
  2. How do you make a custom PID???
    By WiseGuyZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 10th, 2007, 11:20 AM
  3. What do I need to make V1 flash new OS ?
    By RPO_Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2007, 03:30 PM
  4. Dry Shot 50hp
    By oztracktuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 4th, 2007, 01:14 PM
