Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: filter setting
    Jul 2008
    Default filter setting
    im trying to figure out how to auto tune the VE table using the RR but im a bit confused at what needs to be entered into the filters.
    for example im in table B0101 in a 2002 f-body ls1 cal.
    I click on the filter icon and up pops filter set 1 and filter set two tabs each contain 4 main boxes
    Jul 2008
    no ideas? hummm ive done searches and nothing
    More info (I don't know if this helps): roadrunner-efilive-with-rtacs
    Have a read thru this: >>> RoadRunner-FAQs <<<
    I think you just use a transient filter.
    I haven't a clue...
    See here: RTACS-Filters
    Nov 2006
    I always filtered out RPM below idle
    when WBO2 not active & high throttle transitions.
    calc_pids work well for filters.
    LC-1 WBO2
    Jul 2008
    thanks guys. I will give it a try
    Jul 2008
    ok, this may seem a bit dumb but I went out started the car with the efilive tuner open , RR on and connected, the efilive scan tool connected and viewing data. now if I go to set the filters on the RR I cannot select anything in the drop down. what am I doing wrong? do I have to go to the calc pids and copy and paste into the RR filter directly?
    Nov 2006
    Was the scan tool recording?
    All valid pids being recorded should be available.
    LC-1 WBO2
    Jul 2008
    I know for sure I had it on pause (just viewing data while I was trying to get it setup) I thought I tried while recording briefly before shutting the car off but I cannot say 100% yes I will try
  1. Filter Sets
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 17th, 2008, 07:17 AM
  2. Particle Filter
    By nqcv8 in forum General (Diesel)
    Last Post: April 11th, 2008, 01:18 PM
  3. wideband filter?
    By pwilson22000 in forum General
    Last Post: July 13th, 2006, 05:10 AM
  4. map independent filter setting request
    By redhardsupra in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2006, 11:24 AM
  5. Filter Question??
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: July 27th, 2005, 10:13 AM
