Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: filter setting
  1. #31
    Lifetime Member limited cv8r's Avatar
    May 2005
    Ok,I had another look at your screen shots and noticed that you are using imperial settings,so I'm going to have a guess here and say that there is a miss match of imperial and metric between the scantool & tunetool. If you go to your pid selection in the scantool & right click on the SAE.MAP Pid you should be able to switch that pid to metric. Try that and see how you go.
  2. #32
    Jul 2008
    this would be the case even with your log too?
    just gave it a try still no luck.. man this thing is driving me nuts
  3. #33
    May 2005
    Quote Originally Posted by myws6formula View Post
    True.
    If you load your tune & my log or a new one of your own with the suggestions above it should work for you.
    With the SAE.MAP set to imperial in the scantool it is basically sending PSI to the tunetool & B0101 is in kpa not psi. That's why you need metric for SAE.MAP in this instance.
  4. #34
    Jul 2008
    Well there you go! I loaded your log and changed the map pid to metric and there it goes
    THANK YOU! hope this helps future people who run into this
  5. #35
    +1 what cv8r said...
    tunetool MAP axis being stuck on the 15 kPa column is a sign that scantool MAP units are in psi.
  6. #36
    Jul 2007
    The RR/EFILIVE combo is a powerful tool once mastered. Was fun today to setup the software, take a pleasure drive around town and let the software/hardware do all the work.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
  1. Filter Sets
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 17th, 2008, 07:17 AM
  2. Particle Filter
    By nqcv8 in forum General (Diesel)
    Last Post: April 11th, 2008, 01:18 PM
  3. wideband filter?
    By pwilson22000 in forum General
    Last Post: July 13th, 2006, 05:10 AM
  4. map independent filter setting request
    By redhardsupra in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2006, 11:24 AM
  5. Filter Question??
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: July 27th, 2005, 10:13 AM
