Results 1 to 6 of 6
Thread: Does the "C7001 Injection Shutoff vs RPM" work?
    Apr 2012
    Default Does the "C7001 Injection Shutoff vs RPM" work?
    Posted this on CompD and didn't really get any responses. I see it's been discussed in a few threads, but never had a thread dedicated to it here.
    "For each main injection event this is the maximum degrees past TDC the injector will be allowed to remain open based on engine RPM."
    So I changed it from these values:
    Code:
    Injection Shutoff vs RPM (Degrees)
    0 42.007813
    500 42.007813
    1000 42.007813
    1500 42.007813
    3000 42.007813
    3200 39.992188
    4000 33.992188
    To these values:
    Code:
    0 12.007813
    500 12.007813
    1000 12.007813
    1500 12.007813
    3000 15.007813
    3200 15.007813
    4000 15.007813
    That was the only thing I changed in this tune. The truck would hardly start and when it did, it was coughing large amounts of raw fuel. This is something I wouldn't expect when I limited fuel injected after TDC. Has anyone else used this table? Does it do what it says it does? Any reason I'd go from a full-functioning tune (ran a 11.90 earlier that week with it) to nothing?
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    It does work, but you have those limits too low and without seeing your timing or duration values, there's no telling what have going on.
    1207 HP / 1612 TQ
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    I don't understand. If he's not calling for more that 12* at idel I dont see why it would affect idel? Could it be shutting the injectors down before the injector duration is finished?
    Dec 2009
    Those numbers are AFTER top dead center, not before.
    More than likely what he has going on is he's calling for main timing at or after TDC at idle and then limiting it to 12 degrees MAX after TDC.
    That will sure as hell make it not run.
    1207 HP / 1612 TQ
    May 2009
    I have set the whole table to 50* and it developed a rev limiter like surge at 2800ish rpm and wouldn't rev past that why is this?
    Dec 2009
    Again, without seeing the tune and knowing the whole picture its impossible to know what you have going on.
    1207 HP / 1612 TQ
  1. "Paste & multiply" doesn't work?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2013, 01:12 PM
  2. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  3. Methanol "Alky" Injection
    By bobbycollier in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 19th, 2009, 03:21 AM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. "injection timing IAT" multipliers..
    By killerbee in forum Duramax LLY
    Last Post: January 29th, 2007, 08:48 PM
