This is my first go at scaling a Cal it would be great if someone could do a quick sanity check for me to ensure I haven't missed anything. I have learned a bunch with this car through it's mechanical trials and tribulations. The car is a '97 A4 Vette with an LSX deal and a ProCharger.
Attached are the cal prior to scaling with a log file, cal after scaling with the log file (note I didn't do a full sweep was doing steady state) then a cal file after a bunch of changes including some errors/learnings and the final log file. So after all of this I believe I should have done a sweep and checked the top of the MAF as with the final Cal it is going to 512g/s, 112% Duty Cycle and still going lean (especially noticeable on the dyno). I believe I have run out of pump and so have had a larger pump and MSD controller installed. I am going to "back up" to the scaled cal and proceed from there. Comments are greatly appreciated. A great thanks to Greg your DVD was a superb assistance!
Also this is my first go around on Auto Trans tuning. I have not touched the shift curves at all yet, only the pressures.
LS1JeremyWiddup_31March2012_MAF_Unscaled.tun
Log_0012_Unscaled.efi
LS1JeremyWiddup_1April2012_MAF_Scaled.tun
Log_Scaled.efi
Attachment 12942
Log_ScalledPlus_DutyCycle.efi
