Can anyone share what they use when they dyno and track log?
I have a supercharged LS3
also looking for a map that has rpm.tps.afr logging and rpm.tps.psi
like to have it in PSI and MPH format
and help would be appreciated
like to have
Data=A/F
Column=TP
Row=RPM
Data=PSI
Colum=TP
row=rpm
And any other that you could use to data log at drag strip
Thank you
Goto the Maps tab;
click a letter tab (i.e. A);
click the map properties button (hand pointing down),
on the Data tab select AFR pid (the one that works for your E38), on the Col tab select TP, on the Row tab select RPM, click Save As and giv it a filename;
repeat for MAP.psi.
Also see user manual pdf.
Thanks Joe... Do I need to do something special to log PSI numbers I have dont look right.
Thanks for your time
file log I hope I did it right
