Thanks guys for the addition of additional upshift shift time tables for the different shift patterns on some of the operating systems!!!!
Wow, I dont spend much time tuning T43s (yet), but from the looks of it everyone who wants to tune for a higher stall converter and dial in the shift pressures in the different modes is set! I think that was what everyone was wanting to have added for a while, am I missing anything else?
I didn't even know about the new tables
Thanks for the heads up Rhino and a big thanks to EFILive for opening up the T43 even more
All i can say is......... WOOOOOHOOOOOOOO..........answers to the curiosities i had are now complete!!!
Thanks EFI live team!!!
regards Scotty
2008 HSV GTS LS3
I don't do a lot of T43 stuff, so what are the new table id's (for my benefit), please/thanks
Hello Joecar,
The most recent new T43 tables include:
- TCC Slip Test
- D2309
- D2297 – D2308
Shift Times
- previously only one parameter per shift event
- now there are two parameters (some OS have 3 parameters)
- can now adjust the Normal mode shift times (shifter in the “D” position) and the Manual / Sport mode shift times (shifter in detent below “D” position – often “M” or “S”)
The most significant change to tuning the T43 was the introduction of the Torque Model in the accompanying ECM (E38 / E67 / etc.). This innovation was a fundamental change in ideology – an excellent example of “thinking outside the box”.
In a very brief period EFILive has gone from being behind on the T43, to clearly having an advantage over the competition – the Torque Model.
In my opinion the T43 tuning parameters are about 99% complete. The only welcome additions would be the TCC Max Pressure / Regulator Offset / Regulator Gain. These have a similar function to TCC lock up control as do the TCC Solenoid Min / Max PWM parameters with the A4 (4L60 / 4L80).
I could not be more pleased !
Taz
Taz, thanks, good short summary (I like short summaries).
Water off a ducks back
I must confess I had forgotten that I'd been working on more than just the TCC slip stuff, T43 has been a long work in progress update.
The feedback on the ECM Torque model has been great, I think this was definitely a step in the right direction in making the T43 work with us, not against us.
At the same time as the T43 updates I was also mapping the T76 which is very similar to the T43 but for FWD cars, like the Turbo Buick, Cruze etc.
Ijust put a 2800 yank stall in my 08 A6 T43/E38 vette what would you adjust in Torque convertors? Also Can you post a screen shoot for examples? And +/-'s of what your changing.
Also any pids I should be logging also
