Results 1 to 8 of 8
Thread: Vehicle Wont Start
    Apr 2012
    Angry Vehicle Wont Start
    i have 2011 silverado 1500 i purchased a auto cal tuner and went through the whole process of getting tunes for it, i have finally got the tunes in and downloaded them to my auto cal went to the the truck and installed them on the truck, the transmission tune downloaded fine but the engine tune not so much once it flashed the program it brought up a code $06FF and now my wont start.
    has anyone had this problem before
    Aug 2010
    I know very little about the AutoCal ... other than that your direct product support should come from whoever sold the AutoCal to you.
    I believe $06FF is a Checksum error.
    Regards,
    Taz
    That is a checksum failure error, meaning the ECM was not flashed correctly, you should just retry the flash again.
    Apr 2012
    None of that helped very much, the direct support is via email. They replied I guess they have to contact the manufacturer, if anyone has any other suggestions, I am open to them. Thanks you for the help so far.
    Can you please copy the *.ctz (tune file) from your AutoCal to your PC and email it to me at paul@efilive.com.
    Please also send me the *.ctz (tune file) that your tuner sent to you - i.e. the one that you would have copied to your AutoCal device.
    I need to be able to compare the file that your tuner sent to you against the file that is now stored on your AutoCal device - just in case in the process of copying to your AutoCal the file somehow got corrupted.
    Apr 2012
    hey Paul thanks for the support, Justin from black bear got back with me lastnight and we got the problem resolved, i guess the version i had was to new for my truck so he reprogrammed a older model. so its back and running and running good, hey Paul i have a question what can you tell me about the E38-E67 OS upgrade i have read through the tutorial about it on EFILive and i think that it wold be really nice to have a on board tune with a push of a button, have you heard of any problems with it.
    Thanks Brandon
    Quote Originally Posted by bmjlarsen1 View Post
    Good to hear you are up and running again.
    You might have to expand on your thoughts, I'm not quite following what would happen when you 'push a button'.
    Apr 2012
    http://download.efilive.com/Tutorial...20Tutorial.pdf
    if you go to that link it will tell you all about it its pretty cool check it out
  1. help truck wont start!
    By chev in forum General (Diesel)
    Last Post: March 29th, 2010, 02:39 PM
  2. wont idle at start up
    Last Post: May 9th, 2009, 04:56 PM
  3. Sputters wont start
    By chops3131 in forum Duramax LB7
    Last Post: April 22nd, 2009, 05:04 AM
  4. Car wont' start, need some help!
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 10:08 PM
  5. 408 with 90/90 wont start
    Last Post: March 20th, 2007, 11:38 PM
