Results 1 to 8 of 8
Thread: LB7 Lope Tune
    Apr 2012
    Default LB7 Lope Tune
    I got an LB7 duramax and wanna make a lope tune for it. but i dont know where exactly to start anyone with any advice
    Lifetime Member LB72004's Avatar
    Dec 2011
    there are several ways to do it but an easy way is to increase the mm3 in the idle area of the main fuel table.
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Throttle based injection quantity. Go to 0% at 600rpm and put 50mm3 in that cell.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Dec 2011
    ^^ thats a better way. try that first
    Apr 2012
    where exactly is the idle portion in the main fuel table
    Dec 2011
ID:	13104Click image for larger version.
Name:	Warmed up lope.JPG
ID:	13105Click image for larger version.
    i would start with the throttle based one first.
    if you do some logging then you can find out how much mm3s and MPa your truck uses at idle and change only the corresponding cells. i hi-lighted the average area but it may be more or less depending on temp, altitude, age, fuel, etc. logging will show you where you are at. the idle table for temp and the throttle table are the easiest ones to modify as no logging should be needed and is easy to revert back when you get tired of it
    Apr 2012
    Thanks man for your help as u can obviously tell Im new to this and just trying to learn the ropes and just out of curiousity does a lope tune really screw up the injectors
    Mar 2009
    Quote Originally Posted by Hoytmax Diesel View Post
    It sure isn't gonna help em any being shot from open to closed so rapidly.
  1. LB7 smoke tune
    By Hoytmax Diesel in forum Duramax LB7
    Last Post: April 15th, 2012, 02:07 PM
  2. LB7 Lope tune strange issue
    By LBZoom in forum Duramax LB7
    Last Post: January 4th, 2012, 11:39 AM
  3. LBZ/LMM Lope tune
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 12th, 2011, 02:55 PM
  4. LB7 strange lope log
    Last Post: March 5th, 2011, 11:51 AM
  5. Lope tune!
    By jcbduramax in forum General (Diesel)
    Last Post: July 8th, 2010, 01:46 AM
