I got an LB7 duramax and wanna make a lope tune for it. but i dont know where exactly to start anyone with any advice
there are several ways to do it but an easy way is to increase the mm3 in the idle area of the main fuel table.
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
stage 4 SC transmission, 265/70/16 tires
Throttle based injection quantity. Go to 0% at 600rpm and put 50mm3 in that cell.
Dan's Diesel Performance
www.dansdieselperformance.com
^^ thats a better way. try that first
where exactly is the idle portion in the main fuel table
i would start with the throttle based one first.
if you do some logging then you can find out how much mm3s and MPa your truck uses at idle and change only the corresponding cells. i hi-lighted the average area but it may be more or less depending on temp, altitude, age, fuel, etc. logging will show you where you are at. the idle table for temp and the throttle table are the easiest ones to modify as no logging should be needed and is easy to revert back when you get tired of it
Thanks man for your help as u can obviously tell Im new to this and just trying to learn the ropes and just out of curiousity does a lope tune really screw up the injectors
