Hello all,
I have a 2003 Silverado 2500hd with the 6.0L engine running on LPG... I am getting faults picked up with the EFI Live tool which are:
P0172 "Fuel Trim System Rich Bank 1" EPA ($10) "Powertrain Control Module (PCM)"
P0175 "Fuel Trim System Rich Bank 2" EPA ($10) "Powertrain Control Module (PCM)"
P0302 "Cylinder 2 Misfire Detected" EPA ($10) "Powertrain Control Module (PCM)"
P0300 "Engine Misfire Detected" H ($10) "Powertrain Control Module (PCM)"
C0201 "Antilock Brake System (ABS) Enable Relay Contact Circuit" H ($29) "Electronic Brake Control Module (EBCM)"
In regards to the misfire the car still runs fine and the only reason I know its there is because the programmer tells me it is....
Is anyone able to have a look at my logs and tell me if I have a problem with the tune...
cruise log.efi
cartrailer.efi
This is just a normal driving log on my way home and also when I was towing my car trailer...
Now I dont know much at all about the tuning side of it so any help would be really appreciated..
I have recently changed the spark plugs too and put in new iridiums hoping it might fix up the miss but it didnt..
