Results 1 to 7 of 7
Thread: Can BBL log E38 and T43 at same time?
    Apr 2011
    Default Can BBL log E38 and T43 at same time?
    Can you log both on lap top or just on V2?
    Any speccial trick?
    Aug 2010
    Quote Originally Posted by zbadestz View Post
    Can you log both on lap top or just on V2? ...
    BBL (V2) only.
    ... Any special trick? ...
    PIDs cannot have the same name (e.g. VSS) - cannot log ECM VSS and TCM VSS at the same time. I believe once V8 is fully rolled out, the PIDs will be renamed / realigned such that this restriction will be lifted.
    Regards,
    Taz
    Apr 2011
    Thank you
    Senior Member Dieselman's Avatar
    Apr 2010
    Also if you look through your PID list on the BBx setup there is a lot of stuff you can log via the TCM instead of filling up your ECM list. I am logging coolant, intake temps and RPM just to name a few
    Apr 2011
    Quote Originally Posted by Dieselman View Post
    Can I get a screen shot of the rest of your pids?
    Also do you have any maps you can share for reading data logs
    Apr 2010
    Here is a copy of my PID lists 17-10-2011.txt
    Save that to EFILive/V8/tmp and you should be able to open it up in the BBX tab
    Ben
    Apr 2011
    How come on my data log the gear change doesnt match where my rpm changes?
    Does recording to many pids slow it down?
    Also my MPH on my time slip says 139mph but on my data it shows like 129mph
  1. EFI Live T43 Shift Time tune strategy
    By mowton in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 13th, 2011, 08:07 AM
  2. PIDs for E38 & T43
    By mr.prick in forum Gen IV V8 Specific
    Last Post: June 9th, 2011, 09:33 PM
  3. E38 BBL Log Files Hang
    By swingtan in forum FlashScan V2 BB Logging
    Last Post: March 25th, 2008, 09:21 PM
