Page 2 of 18 FirstFirst 123412 ... LastLast
Results 11 to 20 of 172
Thread: Auto VE or Calc VET or Auto Maf?!?!
  1. #11
    When you connect the scantool to the vehicle, do Info->Validate PIDs; you may have to do File->Enter VIN and File->Select Controller also.
  2. #12
    If you're going to do AutoVE (VE enabled, MAF disabled, CL/Trims disabled, wideband only) then make these maps:
    - CALC.WO2BEN map matching VE table (RPM x MAP),
    - CALC.MAFT map matching MAF table (1 x MAFFREQ) if your OS supports the pid GM.VETABLE_DMA.
    If you're going to do AutoMAF (VE disabled, MAF enabled, CL/Trims disabled, wideband only) then make these maps:
    - CALC.WO2BEN map matching MAF table (1 x MAFFREQ),
    - CALC.VET map matching VE table (RPM x MAP).
  3. #13
    May 2011
    So another thing I am wondering is, how do I verify that my MAF frequencies are spot on? Meaning that hopefully it was not tampered with before I bought the vehicle? Or does this not matter?
  4. #14
    You would do AutoMAF to correct the MAF using wideband correction.
  5. #15
    May 2011
    Hey guys! Yes I am finally getting around to having some free time to drive my car although its 100 degrees out here. I honestly have no idea where I went wrong, as nothing will datalog? After re-reading the post, I think i may have not been logging the correct things. Can you take a look? Attached are my log, and my current tune. I did notice its still running about as rich as prior even in this intense heat. Running at about 9.8 on my wideband, I did just calibrate it as well.
  6. #16
    Can you post screenshots of your AutoMAF BEN map...
    I'll look at your files later tonite.
  7. #17
    May 2011
    Well, I guess thats one of the problems! I just looked at it again and its a SELBEN? MAFFREQ for the rows and RPM for the columns but that doesnt even make sense as it goes from 15 to 105. Everything logged in the 105 column as well. Also, when i tried to validate my PID's from the Calc.VET the one it keeps giving me an error on with an X through it is Dynamic air temperature. I also have another logged graph and its VET average, with RPM on the rows and MAP for the columns. Everything it logged showed up as 0's.
  8. #18
    May 2011
    I also couldnt do a screen shot, not quite sure how to do that.
  9. #19
    May 2012
    On your keyboard hit 'Print Screen' when you have the screen up you want to show as a picture.
    Then open MS Paint from your Windows programs. Start>All Programs>Accessories>Paint.
    Then Paste on there and save the image under a name u want it to be.
    Now u have a screen shot u can show here
  10. #20
    Post a screenshot and also your current calc_pids.txt file...
    Does your PCM/OS support the pid DYNAIRTMP_DMA...? If not, the Calc.VET tutorial thread explains how to use your B4901 table to make a lookup calc pid for it... (I can show you how).
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Replies: 5
    Last Post: August 31st, 2011, 10:32 AM
  3. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
  4. Cannot get the PID's for either Calc or Auto VE table
    By ippielb in forum Gen III V8 Specific
    Last Post: May 31st, 2011, 02:09 PM
  5. Auto VE and MAF
    By kistlerjm9 in forum Gen III V8 Specific
    Last Post: April 8th, 2009, 03:20 PM
