Results 1 to 10 of 12
Thread: Tuning learning curve
    Jan 2006
    Default Tuning learning curve
    What seems to be the normal learning curve for learning to tune? I am a mechanic by trade so I am not new to cars. I know the basics behind tuning and I know what I want the car to do. I am just having a hard time learning how to translate the info from the tables of numbers and graphs. For example I know my car at wot gets rich from 3500 rpms all the way to redline. I know it needs to be leaned out and but I don't know how to transfer that into efi live. I have been reading alot of data logging and it is helping some. Are there any good books to read to help learn more about tuning?
    Lifetime Member Doc's Avatar
    Oct 2005
    I agree with your sentiments. EFI University was in my town a year ago. I wish I had my act together then and would have went to one of their classes. Oh well, I am ready to go accross the world to get some real training like that now. http://www.efi101.com/schedule.html
    Please come back to Florida, please. Here is some more internet stuff.
    http://www.ls1racer.com/phpBB2/viewtopic.php?t=1539
    www.efialchemy.com
    www.greatamericancarwar.com
    Jul 2005
    'how to tune and modify engine managment systems' been a great book explaining every little aspect to me so far. not the most in depth book, but enough to explain in proper terms everything you'll find in the forums.
    stickies are awesome tho, help a lot.
    Nov 2003
    Talking
    You are always in the learning curve. There is always something new or new way of tuning. I have been learning for about a year on EFILive. Good luck.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Jan 2004
    Quote Originally Posted by BowlingSS
    Bill
    I couldn't agree more Bill. If you aren't learning more, then I personally don't feel you are applying yourself enough.
    Jul 2005
    yup, one more vote for 'the more you know the more you're confused' situation.
    the more i get a feel for how most tables shape up, the more i realize how you need to account for all the inherent imprecisions and variables that are beyond our control (aka temp, humidity, etc)
    i've been working more on methodology and calculating 'daily acceptable oscillations' than actual tuning, and it's helped me tremendously on getting my tunes to be more consistant, predictable, and therefore allowing me to push it closer to the edge.
    Learning curve is initially fairly steep and requires alot of reading and trying and asking questions
    (always remember: there are no dumb questions, it just means there was a failure to understand).
    The curve does flaten out some, but it slopes upward, there's always more to learn, just like Bill and Chad said.
    And when you think you know something, it throws you into a steep hole, confuse you till it hurts, just like RHS said.
    But you'll get to know your car VERY well (Mrs may get jealous) and you'll instinctively know what's wrong with it when it goes bad (your neighbours will think you're "Mr Hot Rod").
    Some people get interested in cooking, woodworking, antiques, boating...
    Others are interested in tuning their ride, and this is good because it hauls you to/from work each day (or down the track).
    You'll never regret going along this path, I'm sure the "DIY Tuner" will one day be remembered historically
    (in the "24th and 1/2 century").
    Use the scan/tool cursor link feature to show you how a scan log relates to a tune table
    e.g. log RPM and MAP, and with the scan tool showing the chart log (position the vertical cursor), go look at the VE table in the tune tool and see the hightlighted cells.
    This helps alot in starting to understand.
    Jan 2005
    Wait till you get around to the idle. It's mind blowing the number of 1's and 0's it took to replace a screw.
    And Joe made a very good point. My war department like to castrate me for spending 2 weekends in the garage (tuning idle) and coming in the house at late hours reaking of premium.
    Jan 2006
    Quote Originally Posted by Black02SS
    I agree. I learn something at work everyday, maybe something small sometimes but as long as you apply yourself and listen to what others say you can never get enough info.
  1. learning curve /dpf /mileage,What should I expect
    By sledbuilder in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 21st, 2009, 03:36 PM
  2. Ideal Blower WOT AFR Curve
    By white01ss in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 30th, 2008, 08:14 AM
  3. Can 4-3 downshift curve be at/below 2-3 upshift?
    By Mach2 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 11th, 2007, 04:51 AM
  4. Suggestion: 2D curve scan/tune highlighting
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2006, 03:09 AM
