Results 1 to 10 of 19
Thread: Just bought GM/Dodge V2- CAN'T SCAN, CAN'T TUNE, CAN'T READ, NO TEXT.OPTIONS.
    Jun 2005
    Exclamation Just bought GM/Dodge V2- CAN'T SCAN, CAN'T TUNE, CAN'T READ, NO TEXT.OPTIONS.
    I used the install cd. Did the updates.
    NOW I HAVE A $1500.00 PAPER WEIGHT THAT LIGHTS UP!
    I even tried to connect with 7.5 scan tool and prompted incompatible with 7.5, download and install 8.
    WHAT THE HELL DO I DO TO GET THIS WORKING.
    EFILIVE V8 SCAN AND TUNE APPLICATION shortcut is on my desktop. V2 control panel shows up when v2 is connected to my laptop. F2 Scan and F3 Tune says Not Released.
    So where do I go to open a freaking scan window?
    Frustrated. YUP. I google searched and saw I wasn't the only one.
    Christopher's -10cc Alum 6.6L '01 T/A FIREHAWK Recaro Topline Leather/Suede Seats
    Ported L92 Heads, Custom Cam, L76, F.A.S.T. 90TB, 104Lid, CLSD, Kooks 1 7/8 stepped 2", 3" True Dual X-pipe over-the-axle, 3.90 gears, Tubular K, Upper/Lower tubular A-arms, full UMI suspension, etc.
    Brenda and Her Custom Red/Black '01 WS6 Performabuilt stalled A4, Custom Cam, Kooks 1 7/8", 3:42, lid/K&N, Loudmouth, Full Custom Interior, Playboy Package.
    Jun 2005
    Don't know if this helps but in this C:\Documents and Settings\All Users\Application Data\EFILive\V8\
    I do not have an efilive under Application Data.
    Member Laychut's Avatar
    Jan 2011
    Hi Dragon,
    You need to ensure you have the lates Bootlog and Firmware. If you have not already, go to the link below and download both the V8 and V7.5 software.
    http://www.efilive.com/index.php?opt...=48&Itemid=133
    You then need to connect your V2 and update the Bootlog and Firmware by folloing the directions in the link below.
    http://forum.efilive.com/showthread....-V8-1-Software
    I think you will find that everything should work then.
    Laychut
    Going places no one else dares to Go!
    60 Series Landcruiser, GenIII LS1 5.7, 4L60E Trans, 4" Stainless Snorkel
    4" Lift, 35 x 12.5 BF Goodrich Mud Terrains
    Jun 2005
    Went to F6 Firmware in the Control Panel: V2 Bootblock version is ok.
    V2 Firmware version is ok.
    I wasn't prompted with anything when I hit refresh; only that the versions were Ok.
    Jan 2011
    What version Firmware and Bootlog do you have?
    Jun 2005
    I work 3rd shift so I will have to check this afternoon.
    Is this the only place for customer support issues? I tried emailing Andrew Jensen a series of questions before I purchased the V2 but received not one response to my queries.
    So I bought it anyway.
    No 800 number? IM?
    For a purchase that equates to nearly 1500 bucks with shipping, customer support needs to be far better.
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Typically the reseller you bought it from should be giving you the support unless you bought it direct.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Jan 2011
    Hi Dragon,
    You can lodge a ticket by following the below link.
    http://www.efilive.com/index.php?opt...146&Itemid=145
    or You can also send one of the Administrators a PM by clicking on the below link. They normally are pretty good in responding in a timely manner!
    http://forum.efilive.com/showgroups.php
    Laychut
    I feel your frustration, relax and take a step back for the afternoon. Find out what EFILive V7.5 and V8 versions you're running (should be V7.5.7 build 204 and V8.2.1 build 195, firmware 2.07.27) and report back to us when you can.
    For now, V7.5 is the scan tool and tune editing program, V8 is to configure your V2 for standalone logging/reading/flashing. Both V7.5 and V8 can read and flash tunes (certain controllers are only supported by one or the other, all Cummins reads/flashes need to be done in V8. Plus V8 is faster to flash than V7.5 anyway!). So for a Cummins, you need to open V8 Scan & Tune, click F3 Tune, click F2 Read, select the proper Cummins controller (right click the ECM box), then click read. Once you have read it, then save it to a save place and make an external backup or two (in case something happens to your computer). Now close V8 S&T and open V7.5 Tune tool, File->Open and select the Cummins file you just read. Click Open and you should be able to see the calibrations now. Save it as a *.ctz file when you're done, then close V7.5 and open the file in V8, click the Full Flash button (all Cummins need to be full flashed every time, most GM controllers do not), then click Flash.
    Who did you buy it from...?
    When you get a chance, post the V7 build version (do Help->About) and V8 build version (you can see it when V8 is open);
    you want V7 to be build 204 and V8 to be build 195 as was said above by LayChut and Erik.
    What does V8/HAPI say the bootblock and firmware versions are (click on the V2 icon in the tray next to the clock, goto Firmware)...?
    you want bootblock to be 2.07.04 and firmware to be 2.07.27 as was said above.
    Don't use the CD, the software versions on it are already too old.
    Andrew usually responds to emails unless he's on vacation or something.
  1. Tune pulled from car i bought. Can anyone look over it and help?
    By FlipediS in forum Gen III V8 Specific
    Last Post: May 12th, 2011, 06:32 PM
  2. cannot read or scan ECM after BBF flash
    By THEFERMANATOR in forum Duramax LB7
    Last Post: March 27th, 2011, 02:36 PM
  3. no options text found
    By minytrker in forum FlashScan V2 BB Logging
    Last Post: October 10th, 2009, 06:05 AM
  4. can't read scan files without sd card?
    By SS2win in forum FlashScan V2
    Last Post: June 22nd, 2009, 03:28 AM
