Who all is logging the LC1 thru the EGR?
Ive got mine wired up, but having trouble getting it to read in the scan tool..
Starting over this weekend and seeing what happens.
Did you enable EGR in the tune...?
Did you make calc pids that converts GM.EGRS to AFR/EQR/Lambda/BEN...?
I did enable EGR in the tune.
I couldnt figure out how to make the Calc Pid.
Also cant get any of the EGR PIDs to show me voltage.
Is your calc_pid.txt file modified...? If so post it here and I'll edit it, otherwise I'll post one.
Is your LC-1 programmed to output the standard 0V=7.35AFR and 5V=22.35AFR...?
Try this calc_pids.txt file (attached)...
the new pids are:
CALC.FUEL.AFR
CALC.FUEL.lambda
CALC.FUEL.eqratio
and I modified the pid CALC.WO2BEN to use CALC.FUEL.lambda.
But why? Seems so 2002 to do it this way.
its alot easier to do it this way than having to keep up with the lil orange plug.
ill have to save everything on a jumpdrive and post up tom.. im on a company computer and no internet at home :(
Doing it thru the EGR means you don't have to run a new wire thru the firewall.
ok, fair enough.
