Results 1 to 4 of 4
Thread: 4L80E Will NOT SHIFT WOT
    Jun 2007
    Default 4L80E Will NOT SHIFT WOT
    Guys can anybody take a look at this tune and see why this car will not shift under WOT to 3
    The 1-2 shift happens as commanded.
    The 2-3 shift at WOT just will not occur. I have tried all kinds of stuff and no luck.
    The 2-3 shift is set at 70MPH and 6000 RPMS and car will go 100MPH in 2nd gear so the speed makes it no problem and so should the RPMS.
    Any help would be great.
    4L80E not shift 8th burn_0000.tun
    Aug 2010
    Hello Mike,
    Somewhere between the 4L80 segment swap, and COS upgrade, it looks like some of the transmission up / down speeds got a little muddled.
    Try the attached tune - hopefully it helps get you going - such that you can fine tune to your own preferences.
    Regards,
    Taz
    Oct 2011
    I had similar trouble with an incorrectly configured transmission output speed. I'd play with that as the speedo may be correct but the trans may not be.
    Dec 2008
    Quote Originally Posted by ls1mike View Post
    X2. The scanner speedo isn't what the transmission goes by.
  1. 4L80E, unexplainable code 68 and weird 4-3 shift.
    By team-pontiac in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 19th, 2011, 12:49 AM
  2. Adaptive Shift Times 4l80e + HD2
    By 2500ak in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 26th, 2010, 09:22 AM
  3. wot shift question
    By steve40 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 10th, 2009, 01:20 PM
  4. WOT Shift, 1-2, 2-3
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 25th, 2008, 01:24 PM
  5. Vortec 7400 4L80E has TCC locked @ WOT?
    By N0DIH in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 1st, 2007, 12:18 PM
