Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: Help With DTC's
  1. #11
    Jan 2005
    Thanks Joe!
    Can't wait to figure out the cause of this problem. It does make for interesting bragging rights though.
  2. #12
    This one's hard because it happens while vehicle is moving (WOT)...
    Must be worth about 10,000 bonus BR points when you nail it...
  3. #13
    Quote Originally Posted by Black02SS
    WOW. Thats a reply. Talk about informative.
    Thanks mate.
  4. #14
    I found more info on my Helm's:
    Data Link Communications Circuit Description
    Data Link Connector (DLC)
    The data link connector (DLC) contains the class 2 serial data links:
    The DLC also provides a power source for the scan tool as follows:
    • Unswitched voltage (B+) at DLC terminal 16 (circuit 540)
    • Ground at terminal 4 (circuit 650) and terminal 5 (circuit 451)
    Class 2 Serial Data Link
    The class 2 serial data link allows the following modules to communicate data with each other:
    • Electronic brake/traction control module (EBTCM)
    • Instrument panel cluster (IPC)
    • Powertrain control module (PCM)
    • Inflatable Restraint Sensing and Diagnostic Module (SDM).
    The Class 2 serial data link allows a scan tool to communicate with the above modules for diagnostic and testing purposes. The Class 2 serial data link is located at the DLC connector terminal 2. Terminal 2 consists of the following circuits:
    • Circuit 1036
    • Circuit 1128
    • Circuit 1049
    • Circuit 1122
    • Circuit 1132
  5. #15
    Data Link Communications Components
    Name
    Location
    Locator View
    Connector End View
    Data Link Conn (DLC)
    Under the IP, right of the steering column
    Data Link Communications Component Views
    Data Link Communications Connector End Views
    Electronic Brake Control Module (EBCM)
    Mounted with brake pressure modulator valve on the top of the left front frame rail
    ABS Component Views in ABS Traction Control
    ABS Connector End Views in ABS Traction Control
    On the floor tunnel, below the rear of the console
    Hydraulic Brakes Component Views in Hydraulic Brakes
    SIR Connector End Views in SIR
    Instrument Cluster
    On the left side of the IP
    Instrument Panel, Gages, and Console Component Views in Instrument Cluster, Gages and Console
    Instrument Panel, Gages, and Console Connector End Views in Instrument Panel, Gages, and Console
    IP Fuse Block
    On the left end of the IP carrier
    Instrument Panel, Gages, and Console Component Views in Instrument Cluster, Gauges and Console
    Powertrain Control Module (PCM) (V8 VIN G)
    On the right side of the engine compartment, rear of the wheelhouse
    Engine Controls Component Views in Engine Controls
    Powertrain Control Module (PCM) Connector End Views in Engine Controls
    Star Connector
    Under the left side of the IP, near the DLC
    Lighting Systems Component Views in Lighting Systems
  6. #16
    Continued...
    C200D (48 cavities)
    Part of the IP harness, between the left kick panel and the steering column
    Harness Routing Views in Wiring Systems
    Inline Harness Connector End Views in Wiring Systems
    C220 (10 cavities)
    IP to engine harness, under the right side of the IP, behind the knee bolster
    C230 (10 cavities)
    G110 (V8 VIN G)
    Attached to the rear of the left cylinder head
    G200
    Near the left A-pillar, bolted to the IP mounting stud behind the kick panel
  7. #17
    Jan 2005
    Joe - If it's not too much trouble, could you post the info at the other end of the following hyper links? Thanks
  8. #18
    ABS Component Views
    Figure 1: Center of I/P - Chevy
    Figure 2: Accelerator and servo control module
    Figure 3: Front wheel speed sensor
    Figure 4: Left front frame rail
    Figure 5: Right side of auto trans - V6
    Figure 6: Left side of manual trans - V8
    Figure 7: Rear axle (speed Sensors)
    Figure 8: Top of rear axle
    Which of these do you want expanded...?
    These show the named component location in vehicle.
    Don't follow the links.
  9. #19
  10. #20
    TAQuickness,
    I'm guessing you need EBCM pinouts....
    Connector end view diagram goes here, see attachment
    Connector Part Information
    • 1532-6390
    • 30 Way F GT 150 Series Sealed (BLK)
    Pin
    Wire Color
    Circuit No.
    Function
    1
    BRN
    882
    Right rear wheel speed sensor signal (LS1 with NW9)
    2
    Not used
    3
    DK GRN
    872
    Right front wheel speed sensor signal (LS1 without NW9 and L36)
    3
    WHT
    883
    Right rear wheel speed sensor return
    4
    DK GRN
    872
    Right front wheel speed sensor signal (LSI with NW9)
    5
    TAN
    833
    Right front wheel speed sensor return
    6
    LT BLU
    20
    Stop lamp feed
    7
    Not used
    8
    PNK
    739
    Fused ignition feed
    9
    TAN/BLK
    464
    Delivered torque input (with NW9)
    10
    Not used
    11
    WHT
    121
    Tachometer input (with NW9)
    12
    BLK
    150
    Ground
    13
    RED
    302
    Fused battery feed
    14
    ORN
    440
    Fused battery feed
    15
    BLK
    651
    Ground
    16
    Not used
    17
    BRN/WHT
    1571
    Traction control switch signal (with NW9)
    18
    PPL/WHT
    1572
    Traction control lamp control
    19
    GRY/BLK
    1687
    TCS spark retard signal (LS1 with NW9)
    20
    LT BLU
    830
    Left front wheel speed sensor signal
    21
    YEL
    873
    Left front wheel speed sensor return
    22
    BLK
    884
    Rear wheel speed sensor signal (LS1 without NW9 and L36)
    22
    BLK
    884
    Left rear wheel speed sensor signal (LS1 with NW9)
    23
    RED
    885
    Rear wheel speed sensor return (LS1 without NW9 and L36)
    23
    RED
    885
    24
    Not used
    25
    LT BLU
    1122
    Class 2 serial data
    26
    Not used
    27
    ORN/BLK
    463
    Requested torque input (with NW9)
    28-30
    Not used
