Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Help With DTC's
  1. #21
    TA, you may also need the ABS schematics since these show the EBCM wires...
    Cheers
    Joe
ID:	442   Click image for larger version.
ID:	443   Click image for larger version.
ID:	444   Click image for larger version.
ID:	445   Click image for larger version.
  2. #22
    Jan 2005
    WOW Table 3 and Table 4 I believe. The EBCM pinout looks like it will be very helpful as well. Thanks
  3. #23
    Jan 2005
    Or better yet, can you tell me where I can get a copy of the documentation you have?
  4. #24
    www.helminc.com sells the paper and CD/DVD manuals.
    In 2003 I got the 2003 GM ('96-'03) CD and it was $300.
    The current one they have is the 2005 DVD ('98-'05) and it's $400 (price went up).
    If you got more than one GM car and you do your own car work, this is actually very cost effective since it contains all the manuals for all the GM cars in the years specified ('98-'05); you can see that the information contained in these is very extensive.
    http://www.helminc.com/helm/product2...C9WNMV4PQK02M2
    Edit: this covers all North American GM vehicles
  5. #25
    Quote Originally Posted by TAQuickness
    No worries, I'll do this later tonite (my GM CD is installed on my PC at home).
    Oh, I just realized the EBCM pinouts is Table 3, see bottom of thread page 2
  6. #26
    Sorry, I got home very late last night...
    Here is Table 4 "Traction Control Switch"...
    Cheers
    Joe
    Connector diagram, see attachment
    Connector Part Information
    • 1217-7195
    • 6 Way F Metri-Pack 150 Series (BLK)
    Pin
    Wire Color
    Circuit No.
    Function
    A
    PPL/WHT
    1572
    Traction control lamp control
    B
    BRN
    141
    Fused ignition feed
    C
    GRY
    8
    Switch illumination lamp feed
    D
    Not used
    E
    BRN/WHT
    1571
    Traction control switch signal
    F
    BLK/WHT
    451
    Ground
  7. #27
    Jan 2005
    Thanks again Joe. This is a great help
  8. #28
    Jan 2005
    Think i found it. Battery died on me, and with the new battery installed, I noticed it was very easy for it to hit the TCS module under WOT. This should get it all fixed up:
  9. #29
    You mean the battery moved and hit the TCS module (where the throttle cable goes to) at WOT....?
    Good work mate, that plate on top holds it down, nice flat surface for resting tools or oil bottles when working on engine.
    Cheers
    Joe
  10. #30
    Jan 2005
    Cheers
    Joe
    As a matter of fact, I just cleaned and re-oiled the filters and was marveling at the handy table under the hood.
    Also just returned from a run down the BW8 and could not duplicate the problem.
    Thanks again for all the info you posted Joe. It's slowly but surely making it's way into my archives
