Results 1 to 10 of 10
Thread: Base tune needed for 234 243 110
    Aug 2007
    Default Base tune needed for 234 243 110
    Hi basically what i'm after is a something i can stick into pcm to get the car running half decent for when i put this cam in.
    I have a wideband and will be putting it on the dyno for a full tune afterwards just after something close on timing to get it to run half decent.
    Also its a ls6 in a vu ss ute that is a manual. I already have the custom os and it runs mafless.
    Cheers Wade
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Post up your current tune...
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Aug 2007
    Sorry its been so long have had quite a few life changing events happen through out the year that has held up the install of this cam, I'm going to try and do the install of it this weekend if possible.
    I can't find my flash drive at present with all my logs and current tune on it after moving house, I'll go out in the morning and pull the current tune out of it.
    It's only a basic mafless tune with a touch more spark midway and VE adjusted to suit the mafless and big exhaust.
    I do know i will need to get it on the dyno to do the spark timing correctly but just chasing some spark maps to get it up and running half decent for a couple of days till i can get to the dyno.
    Cheers Wade
    Aug 2007
    Just went out and pulled it's current tune
    ute.tun
    Jul 2010
    Hi Wade. let me know your email & I will send you a Cos5 tune i did for a VX (VU) its a 232/234 112...it will still need a lot of work to VE & timing but it will give u a good base file.. I think i only have a auto calibration so just copy the relevant tables over. u may as well upgrade to a cos 5 while your at it too.
    Aug 2007
    pm sent cheers mate
    Aug 2007
    well finally got around to bying myself a replacement sensor for my lc-1 so it's time to relearn how to tune my car again for a bit before i stick the cam in.
    Cheers guys for the tunes so i can look over to work out something as a base spark map.
    Cheers Wade
    Quote Originally Posted by v8manic View Post
    See this: Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
    Aug 2007
    Thanks will have a look over it tonight while i have a couple of drinks.
    Dec 2006
    Subscribed ����������
    8.7 @ 84 (1/8 mile) bolt-ons
  1. v2 saying at 110% wont work help please
    By restless@westnet.com.au in forum FlashScan V2
    Last Post: March 5th, 2012, 12:41 PM
  2. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
  3. base tune 402
    By theoz385 in forum Gen III V8 Specific
    Last Post: February 23rd, 2010, 03:01 PM
  4. Need a base tune
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: August 15th, 2009, 03:14 AM
  5. Base Tune?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: July 9th, 2005, 01:11 PM
