Results 1 to 6 of 6
Thread: Truck losing power... any tips?
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default Truck losing power... any tips?
    Hey Guys,
    I've got a customer with a 2006 5.9, dually....
    We've tried a couple different tunes, they start off really strong and run great for about 30 minutes great, then it loses power and boost..... no DTC's set or stored...
    Fuel pressure is at 160mpa currently, max pulse time of 3200mS, wastegate max duty set at 80%...... all fuel limiters that I could find are set to 145mm3
    I'm sure I'm just overlooking something like a limiter, but any pointers would sure help, he lives a ways away and I'd like to get him wrapped up and back to full power.
    Thanks!
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Junior Member noff's Avatar
    Mar 2012
    are u actully seeing a loss like as in comand fuel or ur duration, or just in the sop feel
    Black06MegaCab/DTT/TDC/EFI LIVE/Gauges/Raptor150/HTTss62-71/AFEPusher/5''ss/TGC8inLongArm/Fox/38''MG ..... RED / 2005 / QCSB / G56 / SBDD / TST / Smarty TNT / ETC... K.I.A.
    Oct 2011
    with 3200 pulse I assume you have stock injectors?
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Post the datalog and lets go from there.
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Jun 2008
    Well that's just it, it always happens after I head home so I have no logs :/
    And yes that's stock injectors. All I have to go on is his word at the moment, but he said when it happens he loses 6-7psi of boost, as soon as we re-flash it everything comes back to life and runs fine for the time that we drive it.
    And I made the mistake of reflashing it last time without logging it in it's depressed state.... whoops.
    Nov 2009
    Only way to know is by datalog of mm3, pressure, and duration...let us know when you get it
    -Kory
  1. 2007 truck Tq management/ reduced power
    By powermonger in forum Petrol / Gas
    Last Post: February 17th, 2012, 03:23 AM
  2. RR Loses VIN and CASE and OLM after losing power?
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 1st, 2011, 03:44 PM
  3. Losing PIDs when opening log file
    By white01ss in forum General
    Last Post: July 25th, 2008, 06:08 AM
  4. LC1 losing connection.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: February 14th, 2008, 01:28 PM
  5. Seem to be losing ground....
    By DaddySS in forum Gen III V8 Specific
    Last Post: April 26th, 2007, 01:14 PM
