Results 21 to 30 of 31
Thread: Why is my Main VE Table zeroing out?
  1. #21
    Jan 2012
    Delberts 5.3, DBC, COS3, 01270003.tun Here is my tune. Injectors are Bosch Blue Top 160lb low impedence injectors that I use a resistor to run. Keep in mind I already have another pcm with an HPtuners tune in it and the car idles, and runs great even with resistors instead of a driver box. I just can't tune it myself with HP because I own EFI live. My current pcm is also a 0411. The specs are in my signature but I am sure the pulse, IFR, etc... is not correct. With this tune it will start but only runs for a few seconds. The Main VE table in this tune is 30% less fuel than I started with but that is how far I had to drop it to get it to start.
    Thanks for any help....
    1969 Chevelle
    Stock 5.3, twin PTE62/62's
    E85, No intercooler
    Th400, PTC Convertor, 3.90 Gears
    Meth/Water Injection
    Factory PCM, Wiring Harness
    EFILive,V1, Daily Driver
  2. #22
    Jan 2012
    Delberts 5.3, DBC, COS3,lamba.tun Okay, I tried to copy cell by cell my HPtuners tune to the EFI live. I realize the axis are different and made sure to double check. With the attached tune I was able to get it to fire up for a second and that is it. I tried adding more fuel slowly in 10% increments and it did not help. Can someone please tell me what the hell I am doing wrong? This is very frustrating. The main thing I did here was change from .068 to 1.00 across the board on the lamba setting.
    1969 Chevelle
    E85, No intercooler
  3. #23
    Can you install the PCM that ran fine, read the tune from it using EFIlive, and then re-install your experimenting PCM...?
  4. #24
    In table C6001 you have to set P0103 to A:1-Trip or Non-Emissions...
    it is currently set to Not-Reported which means that no DTC is reported for the induced MAF failure (table C2901,3), which means the PCM is still using your MAF table which has been zeroed out (B5001);
    you want to see the DTC P0103 being present as confirmation that the PCM is ignoring the MAF and running from the VE.
  5. #25
    Quote Originally Posted by Sinister View Post
    There is a tool that allows you to transpose the rows/columns for when you want to copy data to/from HPTuners.
    Select the entire table of the table you want to copy. Right click and select "Copy with Labels".
    Display the Calibrations window and select the [Conversions] tab page.
    Click on [Create new Table].
    Click the [Transpose] button to transpose the rows/columns.
    Copy/Paste to/from that table when it is in the appropriate row/col format.
  6. #26
    Lifetime Member schwoch1's Avatar
    Jan 2009
    I was thinking the same thing, unless they used one of their COS, then that may be a problem....
    Mike
    Current toys are as follows:
    1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
    1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
    1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
    1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
    1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
  7. #27
    Jan 2012
    I cannot not read the tune using efi live because it is a COS tune. However, I will go out and make the change to the MAF. I do not run a MAF at all, only a 2 bar GM map sensor. I was told it needed to fail to read the VE table I guess I was not making it fail correctly.
    Thanks for the info on how to transpose the data. That could have saved a lot of time. I think I have the VE table pretty close though. Let me go try the MAF issue and I will get back.
    1969 Chevelle
    E85, No intercooler
  8. #28
    Jan 2012
    Delberts 5.3, DBC, COS3, 01270003_00002.tun We are close!!!! Of course everyone is probably asleep now. lol Okay, I made the change to the P103. It didn't make a bit of difference except.......in this tune. Here is the kicker. My fuel pump is on a toggle switch. I have an ignition switch, and then a push button start like nascar. I figured the car has to be flooded so I turned it over without the fuel pump on. It started, it ran for 3-4 minutes without the fuel pump on. How is that possible? I even reved it a little with the throttle. It ran fine. As soon as I turned the pump on it died, like it was being flooded. I have a second pump but it doesn't run until 4lbs of boost. It ran normal without the pump on so I have to think we are close.. Now what? I am going to delete all other tunes since this one seems to work. Don't want to get them confused.
    1969 Chevelle
    E85, No intercooler
  9. #29
    Member scottcmb's Avatar
    Aug 2011
    Is the fuel pump switch back to front?......hence was off the whole time you thought it was on and vise versa
    2008 HSV GTS LS3
  10. #30
    Jan 2012
    No. When you engage the toggle switch you can hear the fuel pump kick on. It is pretty loud. Plus, the toggle switches turn green when on. I have used this set up for a couple years now. The pump is NOT running whatsoever but the car runs and revs like a normal car right now without the pump on. I am not sure how this is even doing this.
    1969 Chevelle
    E85, No intercooler
  1. Question in regards to the main VE table...
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: November 3rd, 2009, 01:11 PM
  2. main VE table
    By 1sikmax in forum E37, E38 & E67 PFI ECM's
    Last Post: May 26th, 2009, 04:36 AM
  3. Main and Boost VE...one table?
    By hquick in forum Custom Operating Systems
    Last Post: February 20th, 2008, 07:10 PM
  4. Use of Main VE Table
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2005, 03:05 PM
  5. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
Tags for this Thread
