hi yer it a 2005 vz ss and i seelected ls1 98/08pcm . i have i have now got it to work intermittent
When you get that error message, there is an option to save it. Please save it as a file and attach the file to the next post, or email it to me at paul@efilive.com
hi m8 yer i did select the correct pcm/ecm
im realy stuk on this the problem started arfter i did a auto update
Try doing a manual install (download/install the files).
Do you mean to do a re install of Efi live
Been investigating this issue, turns out it may be a fault in the V7 Scan Tool software. I'm working on a fix for it now.
The problem occurs when the orange A/D inputs send data back "out of range" values to the V7 scan tool software.
Try logging without anything connected to the orange A/D inputs.
If you do have something connected and your A/D inputs are not correctly calibrated, then it could cause the values to be out of range.
Is it possible that your A/D inputs are not correctly calibrated?
If that doesn't help, you can try logging in stream-slow mode (until a fix is released).
