Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Cummins Injector Pulse
    Senior Member tylerltr450's Avatar
    Aug 2014
    Lightbulb Cummins Injector Pulse
    Hey guys I'm doing some tuning and I want to make my stock injectors act like a little bit of a bigger injector. Im wondering what is a safe range to change and can you move the peak around a little bit in order to help mpg? or do you have to leave it at the stock location?
    Tyler
    Nov 2010
    Lower right corner is the area for power and max pulse depends on trans health.
    Changing cruise pulse to help MPG requires you to log your cruising are to see what cells are in use.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Aug 2014
    Hey Lez,
    Thats my other problem I data logged about 5 times before and now it wont work. I tried reconfiguring everything and it still wont read anything. Since I wanted to log my crusing cells but it wont work anymore. And no worries on the trans im swaping my auto to a nv5600 next week so ill be able to hold the power
    Aug 2014
    update lez on my data logging problem still wasnt working right but I just did this so ill test it on my way home from work.
    I followed the steps in this lets see if it works or not.
    https://forum.efilive.com/showthread...pids+dont+move
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
    Member arinkuddy's Avatar
    May 2014
    I wouldn't think changing your PW in cruse would help with mileage... If you reduce it there truck probably will just command more fuel by increasing mm3
    Nov 2010
    Quote Originally Posted by arinkuddy View Post
    That's where logging comes into play...drop it low enough to help but once it moves into another cell then you know how far you can go.
    Les Szmidt
    2007 5.9 Dodge Ram
    Aug 2014
    Lez any idea on whats up with my data logging. Do you have to have the v2 plugged into the truck before you turn it on? Or can you just plug it in while the truck is running. I did the setup from that link and it still doesn't show data. It shows all zeros and -20 for main timing degrees
    Aug 2014
    Well i figured out my data log problem. It is because im on a old os and not on the csp os. So once I change that ill do some data logging for cruising and hopefully I can figure out a way to increase fuel mileage.
    Aug 2014
    Big thanks to Lez,
    Helped me figure out my uploading tune errors. So now ill start data logging and we will see what I can do with tuning the durations. Yes I did test it and it works with data logging now.
    Nov 2010
    Glad to help...BTW its Les.
    Les Szmidt
    2007 5.9 Dodge Ram
  1. No spark??? No injector pulse.
    Last Post: February 14th, 2009, 03:19 PM
  2. injector pulse width max?
    By pero648 in forum Gen III V8 Specific
    Last Post: April 5th, 2008, 12:47 PM
  3. Small Pulse Adjust/Low Pulse Width Injector Offset
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: September 4th, 2007, 09:05 AM
  4. Injector pulse width
    Last Post: October 7th, 2006, 01:49 PM
  5. Minimum Injector Pulse Width
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2006, 11:28 AM
