Originally Posted by
Blacky
I've been working on this issue all day (thanks Dan for sending your log/trace files).
I managed to reproduce the fault and from there was able to track down the cause. The cause was two separate (and seemingly unrelated) issues which when combined caused the LLY flash to fail. As Ross pointed out and as noted by many users it is because one or more (probably all) modules on the bus were coming "back to life" and interfering with the flash process severely enough to terminate it almost immediately. Obviously bench flashing was not affected because there are no other modules to cause problems.
I have made two changes, one to the FlashScan/AutoCal firmware and one to the LLY reflash script files (E60_W.obj and E60_F.obj). Those changes are being tested now. I hope to be able to post the updates tomorrow once we have tested them completely.
