Results 1 to 8 of 8
Thread: ( New user) Howto remove speed limiter?
    May 2012
    Default ( New user) Howto remove speed limiter?
    Hi every one,
    How to remove speed limiter on yukon 2005 & yukon 2007 ?
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    For the 2005, put speed limiter up in the search window of the tuner and it will take you to the speed limiter - just max out the mph/kph... For the 2007, the E38 controllers have a tricky catch to them - in the tables for speed limiter, H0156 says it is controlled by "other module", you have to change it to "ECM" and max out mph/kph as for others... hope that helps.
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    May 2012
    Thanks Dear BLK02WS6
    hthy
    May 2012
Name:	Speed limiter.jpg
    Again asking this attach picture for 2007 2009
    Now only 158 km how to get top speed?
    thanks
    Aug 2010
    You are using HPTuners software ... post your questions on their website.
    Regards,
    Taz
    May 2012
Name:	Efi Speed limiter.jpg
    Also I use efi live
    Aug 2010
    In EFILive - follow the instructions in post # 2 by BLK02WS6 - set H0156 to ECM. Then set the numeric value of the Speed Limiter to match your application or tire speed rating.
    In HPT change the Speed Limiter "Source" from GMLAN to Calibration.
    If you own both softwares - then applicable tuning questions should be posted on their respective websites.
    Regards,
    Taz
    May 2012
    Thank you verry much My brother (( Taz ))
    Best regards
  1. Remove speed limiter LMM
    By buzzy58 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 8th, 2011, 03:55 PM
  2. Speed limiter
    By RichardWebman in forum E37, E38 & E67 PFI ECM's
    Last Post: August 7th, 2009, 04:41 PM
  3. Speed Limiter
    By devil in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2006, 08:00 PM
  4. help i cant remove speed limiter
    By 5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 13th, 2005, 01:14 PM
