Results 1 to 4 of 4
Thread: Speed density
    Nov 2003
    Default Speed density
    Thinking about giving speed density a try for my dry nitrous setup. Anyone have a SD tutorial? I think it can be done without unhooking the MAF.
    Oct 2003
    Default Re: Speed density
    Quote Originally Posted by Drake
    Without Unhooking the MAF - Engine Diagnostics -> MAF-> Parameters-> MAF High Frequency Fail 1 = 0. It will drop off the MAF.
    Hope this helps some.
    Sep 2003
    Dry shot? Are you sure that is safe? I thought dry shotted cars needed the maf?
    Jan 2005
    Why disable the MAF? It compensates for a multitude of tuning sins and is an excellent "safety valve". A lot of people seem to forget that 1986-89 F-bodies and Corvettes used Mass Air systems and didn't even have MAP sensors, so there was no SD fall back capability. These systems worked fine and could handle some pretty exotic engine combinations.
  1. Do I need the Speed Density COS?
    By MisterGuru in forum Custom Operating Systems
    Last Post: June 4th, 2009, 11:41 AM
  2. Speed Density
    By Yortt in forum Gen IV V8 Specific
    Last Post: December 1st, 2008, 01:11 PM
  3. Speed density run.
    By nissmo in forum Custom Operating Systems
    Last Post: October 30th, 2008, 03:05 PM
  4. speed density
    By mikesp1 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 31st, 2007, 05:29 PM
  5. speed density
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: January 14th, 2006, 06:13 PM
