Results 1 to 7 of 7
Thread: Pid that converts voltage to pressure
    Nov 2007
    Default Pid that converts voltage to pressure
    I want to convert a/c pressure sensor voltage to psi. I looked through the existing pid and didn't find one.
    2006 Trailblazer SS
    Twin Turbo 67 Chevy Truck
    SOLD Truck 2002 Chevy kb turbo t70 5.7l
    Member Laychut's Avatar
    Jan 2011
    Hi aaronr,
    There is a calc PID for converting voltage to PSI for engine oil pressure. I have attached my Calc PID txt with that calc in it. I would think that you could use the same principle for the A/C sensor
    calc_pids.txt.
    It is the bottom calc.
    Cheers
    Going places no one else dares to Go!
    60 Series Landcruiser, GenIII LS1 5.7, 4L60E Trans, 4" Stainless Snorkel
    4" Lift, 35 x 12.5 BF Goodrich Mud Terrains
    Nov 2007
    So my only question is 5v should be 325psi?
    2006 Trailblazer SS
    Jan 2011
    I have attached a Calc txt file that only has the engine oil PID in it. I thought the first one might be a bit confusing.
    Calc_pids_EOPS.txt
    Cheers
    Jan 2011
    You need to know the range of your sensor. This will dictate what 5v equals.
    I am by far NOT an expert on Calc PIDs. Below is a link to where I found the engine oil PID. Maybe these guys can give you better information.
    joecar is good with calc pids.
    http://forum.efilive.com/showthread....l-pressure-PID
    Jan 2011
    Hey aaronr,
    I just found this link that may be helpful for converting your voltage. It also provides the PID to log.
    http://forum.efilive.com/showthread....Pressure-PID-!
    Nov 2007
    Yeah I found that thread after I posted. Thanks for the help
    2006 Trailblazer SS
  1. No Oil pressure PID
    By Laychut in forum External A/D inputs
    Last Post: September 25th, 2011, 09:52 AM
  2. Oil pressure PID
    By odd boy in forum General
    Last Post: October 24th, 2010, 08:17 PM
  3. What happened to my A/C Pressure PID?!
    By Mr. P. in forum General
    Last Post: August 1st, 2009, 11:57 AM
  4. oil pressure pid
    By HINDZY in forum Gen III V8 Specific
    Last Post: May 17th, 2008, 12:59 PM
  5. oil pressure pid
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: December 14th, 2007, 01:27 AM
