Results 1 to 10 of 10
Thread: Trouble flashing my ECM
    Junior Member derrickmanx1's Avatar
    Mar 2011
    Default Trouble flashing my ECM
    This is what I get when I try to flash my 06 lbz
    14:40:15.694: Scanning for EFILive FlashScan V2 HAPI
    14:40:15.708: Autodetect interface ...
    14:40:15.953: Interface firmware version: 2.7.26
    14:40:15.958: Connection to [FSV2] interface is OK
    14:40:15.972: CAN-VPW Bridge Activated
    14:40:16.039: Current protocol set to: "ISO 15765 CAN"
    14:40:16.042: Autodetect ECM...
    14:40:16.170: Connection to ECM is OK
    14:40:16.181: Current protocol: "ISO 15765 CAN"
    14:40:16.394: USB driver version: 4.0.0
    14:40:16.403: USB library version: 3.1.18
    14:40:16.419: Interface firmware model: FSV2
    14:40:16.439: Interface firmware model: FSV2
    14:40:16.457: Interface firmware version: 2.7.26
    14:40:16.474: Interface firmware date: Mar 28, 2012
    14:40:16.491: FlashScan serial number: 003861434913
    14:40:16.509: FlashScan license number: 003861434913
    14:40:16.762: Getting status...
    14:40:16.988: Status: OK.
    14:40:30.903: Disconnecting ...
    14:40:31.511: CAN-VPW Bridge Deactivated
    14:40:31.519: Disconnected
    14:40:32.123: Scanning for EFILive FlashScan V2 HAPI
    14:40:32.141: Autodetect interface ...
    14:40:32.388: Interface firmware version: 2.7.26
    14:40:32.392: Connection to [FSV2] interface is OK
    14:40:32.606: USB driver version: 4.0.0
    14:40:32.611: USB library version: 3.1.18
    14:40:32.626: Interface firmware model: FSV2
    14:40:32.643: Interface firmware model: FSV2
    14:40:32.662: Interface firmware version: 2.7.26
    14:40:32.683: Interface firmware date: Mar 28, 2012
    14:40:32.700: FlashScan serial number: 003861434913
    14:40:32.717: FlashScan license number: 003861434913
    14:40:32.750: Disconnecting ...
    14:40:33.369: CAN-VPW Bridge Deactivated
    14:40:33.377: Disconnected
    14:40:33.988: Scanning for EFILive FlashScan V2 HAPI
    14:40:34.028: Autodetect interface ...
    14:40:34.267: Interface firmware version: 2.7.26
    14:40:34.275: Connection to [FSV2] interface is OK
    14:40:34.293: CAN-VPW Bridge Activated
    14:40:34.361: Current protocol set to: "ISO 15765 CAN"
    14:40:34.369: Autodetect ECM...
    14:40:34.419: Connection to ECM is OK
    14:40:34.436: Current protocol: "ISO 15765 CAN"
    14:40:34.655: USB driver version: 4.0.0
    14:40:34.663: USB library version: 3.1.18
    14:40:34.687: Interface firmware model: FSV2
    14:40:34.705: Interface firmware model: FSV2
    14:40:34.727: Interface firmware version: 2.7.26
    14:40:34.749: Interface firmware date: Mar 28, 2012
    14:40:34.771: FlashScan serial number: 003861434913
    14:40:34.794: FlashScan license number: 003861434913
    14:40:35.049: Getting status...
    14:40:35.274: Status: OK.
    14:40:36.150: Preparing ECM for reflash...
    14:40:36.197: ECM seed is: $29F8
    14:40:36.200: Unlock attempt 1 of 1
    14:40:36.348: Initializing ECM...
    14:40:37.763: Request serial number...
    14:40:38.610: Serial number: 86J624105700
    14:40:41.221: Attempting to reboot ECM... (please wait up to 8 seconds)
    14:40:42.385: ECM has booted successfully...
    14:40:43.390: Clear emisison related DTCs...
    14:40:43.434: Clear DTCs for all modules...
    14:40:45.543: Autodetect interface ...
    14:40:45.785: Interface firmware version: 2.7.26
    14:40:45.787: Connection to [FSV2] interface is OK
    14:40:45.789: Autodetect ECM...
    14:40:45.832: Connection to ECM is OK
    14:40:47.170: Reflashing completed successfully
    14:40:50.319: Done!
    The time is 35 seconds total. There is no way it's flashed. Any help would be great. It will flash my TCM no problem. All software and firmware up to date. I can't even read the ecm's tune.
    Mar 2009
    If you are doing a cal flash, yes it will happen that quick. Takes me about a minute to cal flash a DSP5 into a BOSCH controller.
    Apr 2008
    I will ask the same as I did on the Diesel Place forum. Are you the original owner of the vehicle? If not maybe it is tuned. Have you gone to a dealer to see if they can flash a stock tune in it? If they can't then I would say either some bad or not fully connected wiring or a bad ECM.
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
    Jan 2009
    Run the program as admin, if you dont it will do this. I have all my efi live programs set to run as admin all the time. To run it as administrator just right click the program you want to open then select run as administrator.
    Mar 2011
    I'll definately try the administrator thing when I get a chance to mess with it. It's still running it just won't change.
    Apr 2006
    This is your problem. Run as Admin.
    Mar 2011
    Cig lighter is good. I'm the original tuner because I loaded this tuning into the truck. I can tune the tcm but it will not read the tune or change the tire size of this tune. I've tryed full flashing cal flashing. It doesn't even bring the progress bar up.
    You need to update at least your V2's firmware, latest is 2.07.28. Start with that, then try it again (set the programs to run as Administrator too). Also, if that doesnt work then try using V8 to flash the ECM as well.
    Mar 2011
    I had updated the day before trying this flash. I'll still update it again
    This Admin permissions issue should all be fixed in the next update.
  1. ECM Pins for DSP, trouble with wire...
    By andrewjamesbond1 in forum General (Diesel)
    Last Post: February 16th, 2012, 11:18 AM
  2. Issues with locking ECM then flashing again
    By LBZoom in forum General (Diesel)
    Last Post: October 26th, 2011, 03:42 AM
  3. Trouble flashing in a tune
    By Chris81 in forum FlashScan V2
    Last Post: January 4th, 2011, 09:03 AM
  4. Flashing ECM Alone?
    By Nemo in forum General (Diesel)
    Last Post: April 12th, 2010, 08:18 AM
  5. Trouble Communicating with E38 ECM
    By philip.long in forum E37, E38 & E67 PFI ECM's
    Last Post: January 25th, 2009, 08:33 AM
