Results 1 to 4 of 4
Thread: lly power dropping out at wot
    Nov 2011
    Default lly power dropping out at wot
    i have an lly on the engine dyno and at wide out throttle it will rev to 3400 with no issues but then drop down to idle for several seconds and then go back up-any help would be great!
    Nov 2011
    well, i got the problem figured out. It would seem that the pipe we have the maf sensor in isn't the same diameter as the factory pipe. Does anybody know the size of the lly air intake at the maf?
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Easiest way to tune around this is max out the MAF fuel limit tables to 120mm3. Then your fuel will not be limited by the MAF which is now in accurate. If you want to dial it in you'll need to compare data logs with the MAF pid up at various stages of throttle and rpm with the stock intake and compare to now and scale accordingly.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Dec 2011
    If you have a standard intake such as one meant for an LBZ, then you can just steal the MAF values from a stock LBZ MAF table (and adjusting the max from 583 down to 500 gm/sec). If you have a more custom setup such as a Bill's custom 5" intake, then you'd need to compare airflows at various RPMs and then scale your MAF values to match (as suggested above).
  1. E40 2 bar Dyn Air dropping and so is fueling and everything else
    By Highlander in forum Custom Operating Systems
    Last Post: March 9th, 2015, 09:41 AM
  2. Dropping a marker into a BBL file?
    By JAY4SPEED in forum Black Box Logging
    Last Post: September 8th, 2010, 03:24 PM
  3. Off Throttle Dropping Through Idle
    By SOMhaveit in forum Gen III V8 Specific
    Last Post: August 24th, 2009, 06:49 AM
