Results 1 to 5 of 5
Thread: Bricked H3... almost
    Junior Member SwedeBurb's Avatar
    Jan 2008
    Default Bricked H3... almost
    I came close to bricking my wife's 2007 Hummer H3 3.7L tonight! I could read it without any issues. When I went to reflash it failed... it erased the PCM memory and just when it said it was starting to reflash it failed. I could not get any contact with the PCM after that so I tought I was f***ed. Luckily I was able to reprogram it with GM SPS using a Mongoose cable so the truck is now up and runnig again
    Does anyone know exactly what I need to do to avoid having that experience again? Any specific fuses that need to be pulled or should I just rip out the PCM and bench flash it instead?
    /Stefan
    Have you downloaded the latest V7 & V8 software releases HERE? (Plus update the V2 firmware).
    These contain a fix for a bug that recently popped up that allowed modules on the vehicle to come back to life during the PCM erase which interrupted the flash process.
    Jan 2008
    Yes, I was running..
    7.5.7 (Build 206)
    8.2.1 (Build 197)
    Bootblock 2.07.04
    Firmware 2.07.29
    Should I send you guys the .blx files?
    /Stefan
    Quote Originally Posted by SwedeBurb View Post
    /Stefan
    If you used the V8 software to flash the truck, can you please locate the *.htx trace file of the failed flash and send it to me.
    If you used V7 software to flash the truck, can you please locate the *.blx trace file of the failed flash and send it to me.
    Send to paul@efilive.com
    Instructions on where to find the trace files are at the bottom of this page:
    http://support.efilive.com/kb_articl...8254-QOGC-9586
    Jan 2008
    E-mail sent...
    /Stefan
  1. Bricked 2 E37 ECMs?
    By engimuneer in forum E37, E38 & E67 PFI ECM's
    Last Post: December 15th, 2011, 01:36 PM
  2. Bricked my PCM- What to do?
    By 67RsCamaroVette in forum Gen III V8 Specific
    Last Post: October 23rd, 2011, 08:02 PM
  3. PCM bricked while
    By Chuck L. in forum Gen III V8 Specific
    Last Post: June 29th, 2011, 08:46 AM
  4. Fixing your Bricked V2
    By Ira in forum FlashScan V2 BB Logging
    Last Post: April 18th, 2008, 09:21 AM
