Results 1 to 2 of 2
Thread: E67 Timing issue
    Aug 2010
    Default E67 Timing issue
    I am not sure if this should be in the e67 forum or forced induction. I put i here becuse the E67 supports 2.5 bar with out mods. I am working on a 07 monte carlo turbocharged 5.3 and an auto 4t65e trans. When the boost pressure comes up quickly at higher boost levels (above 16 psig @ 85 kPa baro) a bunch of timing is pulled around 4100-4800 rpm, just like burst knock. I have logged all the knock retards and burst knock pids when it pulls timing and it looks fine. I have been over this tune too many times to count trying to find the problem. It almost seems like the car is hitting a limint in the torque model for the tranmsission but all of the torque limits are maxed out. The problem does show up at max torque only when I am over 600 lb ft to the ground. I have attached one of the logs and the tune. Look at frame 222-292 on the log. To finish getting what i needed for turbo sizing on the dyno I just set B5157 to the timing I needed to run. Any help would be great
    Dec 2007
    Try a few different PID's for more accurate feedback: GM.KR and GM.SEMRET. If it's pulling timing it will be shown in SEMRET also on my E76 it shows knock with KR and not KNKRET so I use that.
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
  1. E67 Injector Bank pulswidth Value issue.
    By railheadwrench in forum E37, E38 & E67 PFI ECM's
    Last Post: November 15th, 2011, 07:55 AM
  2. Possible timing issue?
    By LBZoom in forum Cummins 5.9L
    Last Post: June 23rd, 2011, 01:12 PM
  3. loosing sleep over my 1998 454 -compcams timing issue
    By camminchevy in forum Vortec V6/V8 Specific
    Last Post: April 29th, 2011, 07:01 AM
  4. Timing issue w/'02 Camaro tune on '95 LT1
    By schwoch1 in forum Gen III V8 Specific
    Last Post: March 17th, 2010, 04:11 PM
  5. LMM timing limiter and pilot issue
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 4th, 2009, 03:48 PM
