Results 1 to 6 of 6
Thread: 2001-2002 F-body LTFT cell RPM boundary values
    Default 2001-2002 F-body LTFT cell RPM boundary values
    Questions regarding 2001/2002 F-body LTFTcell RPM boundaries:
    Does anyone know if....
    a. ...changing the LTFT cell RPM boundaries will allow the PCM to now use all 16 cells (rather than just the 4 or 6 it currently uses)...?
    b. ...making this change will cause any problems (why did GM choose these very strange values...?)...?
    c. ...same 2 questions for changing the MAP boundaries...?
    d. ...any suggestions for possible values to use...?
    Oct 2003
    This has been changed by many to increase part throttle LTFT resolution.
    I believe we're WOT, in most cases, above 3600- 4000 RPM (55%-45% TPS respectively). Above 4000 RPM we're pretty much 100% on the MAF.
    FWIW - My Stock 2001 Z06:
    MAP Boundaries -37,57,77 kPa
    RPM Boundaries - 900, 1400, 2200
    joel
    Joel,
    Thanks, good answer.
    Joe
    (Need more emoticons... beer mugs chinking together).
    I would add them if:
    1. I knew how
    2. I knew where to get them.
    Anyone know how to add new emoticons to this phpBB and where to get them?
    Sep 2003
    Default Re: 2001-2002 F-body LTFT cell RPM boundary values
    a. yes you can change them to get more cell resolution. My guess is GM picked those funky values I suppose to pay more attention to the maf and less attention to the map sensors
    b. No mine are 1200 2400 4000, 40 ,60,80 this also made the lines drawn for my LTFT history coincide with even values on my ve table
    c. I dont have a clear cut way to find this out but i iused my values for low idle 2400 for pt driving and 4k for WOT
    Blacky I would be able to help if you needed it
    Dirk,
    Thanks, appreciate your answer.
    Joe
    (emoticon: beer mugs chinking together)
  1. 2001 F-body Emissions Test
    By joecar in forum Gen III V8 Specific
    Last Post: October 18th, 2007, 05:27 PM
  2. LTFC Cell Values
    By Chuff in forum EFILive V4
    Last Post: September 15th, 2006, 12:45 AM
  3. I have a 2000 F-Body; should I change to a 2001 or 2002 OS?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2005, 05:44 AM
  4. cell by cell ltft
    By ahall1 in forum General
    Last Post: June 23rd, 2005, 06:17 AM
  5. LTFT cell matrix
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: March 3rd, 2005, 11:48 AM
