Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: More and more problems with V2
    Oct 2010
    Default More and more problems with V2
    When I bought my V2 about 2 years ago it was rock solid but everytime I do an update it gets worse and worse. Thought the purpose of doing updates was to improve it. I have problems reading LMM now i'm having problems with flashing/reading LB7 that I never had before. I used to just hook it up and go now it keeps giving me bootloader errorrs and what not. The only way I can flash and read it is unclick high speed and click on try alt keys. Whats the deal? I'm afraid to do anymore updates now as everytime I do one it gets worse and more errors pop up.
    Each time you update the V2 firmware do you also do BBx Program All...?
    Quote Originally Posted by pavetim View Post
    You're right, recently there have been problems that have crept into the V2 firmware. I've spent the past month tracking them down and fixing them. An internal update is being tested right now that addresses the read/flash problems on VPW based controllers. That should fix any problems that you have with the LB7.
    As for the LMM failures can you please send me any trace files of any failed LMM reads/flashes as per the last part of this page:
    http://support.efilive.com/kb_articl...8254-QOGC-9586
    Send to paul@efilive.com
    Oct 2010
    The problem with reading a dsp out of LMM is a known problem though isnt' it? How do I do a trace file? So what build should I update too? Right now I have builds 180 and 170
    Oh I see, the reading of a DSP5 tune is not so much a problem as a purposely added security measure.
    Junior Member derrickmanx1's Avatar
    Mar 2011
    Mine is all jacked since trying to update firmware. I think I'm cursed with efilive. I was one of the first to lose a lbz ECM due to flashing. I can't get my flash scan to be recognized by my computer. When I check the firmware it says it is good. Restarted the computer tried all kinds of things went to documents and tried to load the other firmware and it is not working. It is stuck in dead-poll mode can't get it out.
    Quote Originally Posted by derrickmanx1 View Post
    After installing the latest software you can find recovery instructions that may help you get your FlashScan operational again here:
    \Program files (x86)\EFILive\Drivers\V8\Firmware\EFILiveRecovery
    Look in that folder and open the file called ReadMe.txt, try following the instructions in that file.
    Mar 2011
    I wish it worked. I get a error$008E attempt to overwrite firmware with an older version.
    Oct 2004
    I expect that your device has 2.05.08 bootblock and somehow has 2.07.x firmware? If so I believe you will have to send the device into a service agent to be recovered. I tried via remote access for one customer recently and was fla out not able to recover the device ion the field (and I'm pretty good at it ).
    Please go across to our helpdesk (http://suppot.efilive.com/) and log an RMA case and I can advise where to contact.
    Andrew
    EFILive Crew
    Mar 2011
    Nope showing boot block 2.07.04
    And firmware 2.07.29
    Just not acting right though. When I plug it in it powers up with no display and all led's come on. Then it goes to flashing the orange led's alternatively.
  1. Having some problems...
    By CisforCookie in forum EFILive V4
    Last Post: July 7th, 2009, 01:11 PM
  2. V2 problems :(
    By CDR in forum FlashScan V2
    Last Post: March 2nd, 2009, 04:56 AM
  3. need help PC problems
    By way2much_01 in forum Gen III V8 Specific
    Last Post: February 16th, 2009, 12:26 PM
  4. 98 sd problems...still...
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: February 7th, 2009, 06:18 PM
  5. 2 problems
    By 1fastgto in forum Gen IV V8 Specific
    Last Post: December 26th, 2008, 04:27 AM
