Results 1 to 10 of 18
Thread: When will EFILive support 2011-2012 Sierra 2500
    Lifetime Member wesam's Avatar
    May 2010
    Default When will EFILive support 2011-2012 Sierra 2500
    I'm waiting since two years now to have support for GMC Sierra 2500 2011-2012
    in each update i hope that the problem will be fixed but it seems it will take decades :(
    I attached picture for the message i have when i tried to read the tune file from those cars in the attachments
    i have the latest updates and firmware 7.5 build 206 & 8.2 build 197
    this is the VIN : 1GT029CG7BF181024
    please help
    EFILive Tuner
    That message does not mean it is not supported (I don't know if it is or is not supported). It means the controller is most likely locked.
    Can you please send the appropriate *.blx trace file as per the explanation at the bottom of this page:
    http://support.efilive.com/kb_articl...8254-QOGC-9586
    Send to paul@efilive.com
    May 2010
    Paul this problem is facing all the tuner hear in Middle east not just me
    I will send what ever files you want but please tell me what is the path for the needed files
    so please try to solve it for us
    EFILive Tuner
    Quote Originally Posted by wesam View Post
    I really need the trace files or else I can't see what is causing the problem.
    May 2010
    OK files sent
    Looking forward to hear from you
    EFILive Tuner
    Jan 2006
    I have tuned 2011 2500's with E78 ECM's. It didnt have all the tables compared to an E38 but I was able to tune it for the most part.
    May 2010
    Quote Originally Posted by minytrker View Post
    I think it has E38 not E78
    EFILive Tuner
    The 2500 series with the 6.0L switched to the E78 ECM in 2011.
    EFILive has supported the E78 ECM since August 2010. However, you must read and flash E78 ECM's using V8, not V7.
    Jan 2006
    Thats exactly what I have seen.
    May 2010
    Is there any tutorial for using V8 ?
    EFILive Tuner
  1. Support for 2011+
    By rcr1978 in forum Cummins 6.7L
    Last Post: October 23rd, 2011, 05:00 AM
  2. 2011 OS upgrade to 2012 OS
    By dgund in forum E78, E83, E84 PFI ECM's
    Last Post: October 22nd, 2011, 01:44 AM
  3. What pcu and os for 2004 Sierra 2500 HD?
    By TheSignGuy in forum Gen III V8 Specific
    Last Post: September 25th, 2011, 05:01 AM
  4. EFI support for the ford powerstroke?
    By cumminsDK in forum General (Diesel)
    Last Post: August 22nd, 2011, 05:06 AM
  5. support for 2008 GMC Sierra V6 2wd
    By camcojb in forum E37, E38 & E67 PFI ECM's
    Last Post: October 28th, 2008, 03:29 PM
