Results 1 to 8 of 8
Thread: Off boost, no load, transient performance
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Thumbs up Off boost, no load, transient performance
    This was some tuning we did today with no load on the roller, just the drum weight itself, and no boost to start the run, just to simulate normal driving performance. Just went from 1700 RPM's to 3800 RPM's. Remember, the 6.7's fueling is completely dependent on load. If it doesn't have load, it won't fuel.
    The runs once we added load and the boost to simulate launch were ...... a whole lot more dramatic.
    The loaded runs were started at 1700 RPM's and 17 psi of boost. The torque chart was almost vertical and carried 115 HP and over 150 ft/lbs out farther than the owners 840 HP drag truck.
    This is with NO smoothing and SAE correction.
    1207 HP / 1612 TQ
    Dec 2009
    And this was also on stock valve springs......
    1207 HP / 1612 TQ
    Nov 2010
    Gangster!!!!
    Nice smiley faces in the piston crown!!
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Dec 2009
    Naaaah, they're cut down 100.
    He called me from the track a little while ago....
    1st pass .... he was paying attention to the Mustang he was racing and called on 3rd gear a little too quick and snuffed the charger.
    2nd pass .... he blew the tires (33x16 slicks) off through 3rd gear.
    She's definitely making the power.
    1207 HP / 1612 TQ
    Nov 2010
    Cut pistons and stock springs...weird southern guys!!!
    Les Szmidt
    2007 5.9 Dodge Ram
    Dec 2009
    Quote Originally Posted by 2007 5.9 View Post
    1207 HP / 1612 TQ
    Nov 2010
    No disrespect to you rich.
    Les Szmidt
    2007 5.9 Dodge Ram
    Dec 2009
    None taken brotha.
    I'm all for upgrading the valve springs. Running it that hard without them scares the crap outta me, but with 100 thou clearance, they're pretty safe. Not exactly ideal, but pretty harmless.
    He's swapping the springs here shortly and then we'll turn it up some more. Once it hits a little over 60 psi, it noses over.....more boost than seat pressure.
    1207 HP / 1612 TQ
  1. Transient Fuelling Pid
    By 5.7ute in forum Tips and tricks
    Last Post: April 8th, 2012, 11:35 AM
  2. Tuning the transient parameters
    By hquick in forum CAX Files
    Last Post: December 27th, 2009, 12:14 PM
  3. P2563 code "Turbocharger Boost Control Position Sensor Performance"
    By Truckin Stuff in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 3rd, 2009, 01:11 PM
  4. What are the transient tables?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 16th, 2009, 04:33 AM
  5. Transient fuelling????
    By hquick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 25th, 2008, 06:15 PM
