Results 1 to 10 of 11
Thread: Replumbing the PCV pickup point
    Default Replumbing the PCV pickup point
    If you don't have a catchcan or the LS6 valley PCV pickup yet, you can do this for about $4.00...
    I know this isn't EFILive stuff, but it helps to reduce oil induced knock and keeps the plugs, O2S's, cats from getting oil fouled.
    I drilled a 3/4" hole thru my oil cap, installed a rubber grommet, pushed PCV into grommet, reversed flow thru PCV plastic tubes, plugged air nub near front of RHS valve cover.
    When accelerating, alot of oil is pumped up pushrods into valve cover and acceleration pushes oil to rear of valve cover; oil cap is highest position on engine, so no liquid oil will be sucked (...most of the time...).
    This is for the interim until I get an LS6 valley pickup, which I like better.
    The rubber grommet is GM 10198949 and fits nicely into the hole drilled in the oil cap.
    Steps:
    0. Remove PCV valve rubber connection from nub on intake manifold.
    1. Undo nut on heat sink, and remove PCV valve and rubber holder from plastic PCV tube (hold plastic tube, carefully twist holder off).
    2. Extract PCV valve from rubber holder.
    3. Remove oil cap, carefully center and drill 3/4" hole (holesaw or woodborer); drill from underside of cap.
    4. Clean hole and insert rubber grommet, you may need to enlarge the hole a bit, use a round file.
    5. Install oil cap.
    6. Insert PCV valve into rubber grommet in oil cap.
    7. Run some 5/16" ID fuel hose from nub on intake manifold (fits tight, use pliers to stretch ID of hose a little and use oil) to PCV valve in oil cap (go past front of head, form a loop going up, and then come down onto PCV valve).
    8. Remove hose end from nub on RH valve cover and insert on plastic PCV tube (use oil to make hose go on easier); leave other end of hose connected to TB.
    9. Plug nub on RH valve cover with 5/16" rubber cap (from local part store).
    Keep parts taken off (rubber connection, rubber holder) just in case if required to reset back to OEM for smog test inspection.
    Cheers
    Joe
    Jan 2005
    now that's THE most clever AND practicle solution to the PCV oil consumption problem I've heard of yet.
    Aug 2005
    My LS6 PCV setup still pull's some oil. About a pint in 3000 miles.
    Dale
    78 Datsun 280Z W/LS1/T56
    TR230, Absolute Speed stage II 5.3 heads, Fast 90mm setup, JTR 1 3/4 headers.
    Default Oil belongs in the crankcase not in the intake manifold
    It seems to me that a catchcan can be used inline with this replumb.
    Hmmm.... could possibly do the replumb to the LS6 valley also:
    fresh air enters thru LS6 valley, crankcase gases exit thru oil cap;
    ha, with a catchcan also.
    Just a couple of thoughts.
    Aug 2005
    I used a small one from home depot. Works great, I dump it every couple of weeks.
    Dale
    Is that a compressed air water separator... cool.
    Aug 2005
    Yup, works great.
    Dale
    Quote Originally Posted by TAQuickness
    Thanks mate.
    Observation:
    I find that I don't really need a hose clamp on the hose I used
    from the PCV valve to the intake manifold since it is a snug fit.
    Jul 2005
    I had to RTV the needle valve to stop it sucking air. Also a good visual indicater for dirty oil.
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
  1. point me in the right direction
    By Gregs in forum Gen III V8 Specific
    Last Post: April 30th, 2010, 04:48 PM
  2. O2 Switch Point
    By Sid447 in forum Gen III V8 Specific
    Last Post: January 29th, 2009, 09:13 PM
  3. Replies: 8
    Last Post: September 9th, 2008, 11:08 AM
  4. VSS Signal style/type ? (pickup question)
    By J 98ta in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2006, 03:40 PM
  5. 02 switch point...
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2006, 01:18 PM
