Page 14 of 17 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 164
Thread: 427 stroker turbo need help on everything
  1. #131
    Jan 2011
    Here is the sneaky spot i put my bottle.
ID:	13608Click image for larger version.
    Im only slightly crazy.....
    http://www.youtube.com/watch?v=Vff8wi00Bxk
  2. #132
    Jan 2011
    Here is another log. I was into the boost alot more this time through most of the speed ranges. no cops. lol
    I noticed there was ons spot where i was off the throttle and the gauge maxed out on lean, I got into the throttle quickly to bring it down.
    It sounds gnarly into the boost but extremely loud when passing as the wastegate is vented to open air. This will probly be my last log for about 15 days, I gave my dad the flash scan for his duramax. he is goig on a 700 mile trip for work and towing a trailer, so if he had any complications he could work them out...
  3. #133
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    You forgot to attach the log.
    Edit - don't worry about the lean when you are off the pedal - I missed one of the DFCO disable parameters - its normal for it to do that, but I meant to shut it off while we are tuning... it will be off in the next tune... when we are done tuning, I will turn it back on. You want it to lean out on deceleration - keeps it from loading up on fuel.
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
  4. #134
    Jan 2011
    DOH! Howd i manage that! Yeah leaning out that fast kinda scared me. haha.
    427 july 28.efi
  5. #135
    Jun 2005
    Here you go - can you still load this tune? Hope so - even if you can't log it, load it up before he takes the cord...
    GM EFI Tuner
  6. #136
    Jun 2005
    Don't worry about the lean-out on decel, that is normal...
    It is dialing in really good. It will be hard for me to really optimize timing without you putting it on a dyno - I'm going on experience with somewhat similar setups and being conservative... But, if you aren't looking to totally max it out, it will be okay. Like I said before, tuning something like this over the internet isn't easy...
    GM EFI Tuner
  7. #137
    Jan 2011
    Ill be loading and logging this quickly. Luckily he hasnt left yet. Anything specific you want done?
  8. #138
    Jun 2005
    Wide open in boost for as long as you are brave... or at least through 2nd and into 3rd gear...
    GM EFI Tuner
  9. #139
    Jan 2011
    july 28 log 2.efi
    damn! I just got that msg as I got back. I have some harder acceleration on here. If its not enough I may be able to do a second run. not a big deal.
  10. #140
    Jun 2005
    It's looking great! Here are some more changes. If you can't go back out, don't worry about it now... we can always do it later.
    GM EFI Tuner
  1. 427 stroker fuel surge help?
    By hemi_power_3@hotmail.com in forum Petrol / Gas
    Last Post: November 26th, 2011, 11:23 AM
  2. Need some help with a 383 stroker
    By TransTech in forum Gen III V8 Specific
    Last Post: November 22nd, 2007, 05:59 AM
  3. Newbie 383 stroker question
    By TransTech in forum General (Petrol, Gas, Ethanol)
    Last Post: November 21st, 2007, 01:36 PM
  4. Pic of my new 427
    By VortechC5 in forum Lounge
    Last Post: May 19th, 2007, 10:47 AM
  5. 402 stroker injector recomendations?
    Last Post: June 17th, 2006, 07:49 AM
Tags for this Thread
