Results 1 to 9 of 9
Thread: file compares across different operation systems (software)
    Oct 2011
    Default file compares across different operation systems (software)
    The capability to do a file compare across different OS's would help quite a bit. Then you could see the differences across model years, etc. Also, it would spit out the unique params of each OS like what's new and what got dropped.
    Anyone else think this would be useful?
    Coming in Scan & Tune V8 which is in heavy development currently.
    Yes, it's useful... just hard to do when the files/tables are organized differently.
    Senior Member auspeed's Avatar
    Jul 2010
    Is this feature close??
    Quote Originally Posted by auspeed View Post
    Its not going to be in V7, but it is being added in V8. I don't have a time frame for the V8 release of the tune tool yet.
    Dec 2010
    That would be a nice option!
    For now is there any way to open 2 instances of V7 Tune?
    Feb 2012
    Quote Originally Posted by EagleMark View Post
    You can open as many instances of the tune (or scan) tool as you like.
    Jul 2010
    any updates on this?
    The V8 tune tool software is still in development. And it does contain the ability to compare tunes between different OS numbers. I don't have an exact time frame for when it will be released. But a lot of resources are being directed to the V8 software effort and I plan to have a test version available in Q2 2017.
  1. Script file not supported by current software version...
    By Straight 6 in forum Cummins 5.9L
    Last Post: June 27th, 2011, 03:50 PM
  2. DSP5 upgrade-abnormal operation, 01
    By killerbee in forum Duramax LB7
    Last Post: April 25th, 2011, 04:21 PM
  3. Closed Loop Operation Questions
    Last Post: May 9th, 2008, 08:44 AM
  4. Invalid Floating Point Operation
    By edcmat-l1 in forum E37, E38 & E67 PFI ECM's
    Last Post: April 16th, 2008, 03:23 AM
