Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Auto to manual (tune)
    Apr 2012
    That's exactly what I'm looking for actually, I understand they are identical. May see if I can buy a 4.8 manual ecm and get it that way~ was hoping someone might have it already, but I guess not.
    Aug 2010
    Quote Originally Posted by K3vin View Post
    Sorry if this sounds dim, but can I just load the Camaro Man tune onto the 5.3 LM7 ecm and run it on the engine?
    Yes you could. You would need to repin the PCM connectors in your harness to match the Camaro PCM pinouts. The MAF and VE would need to be corrected for the 5.3 L. The Camaro uses a returnless fuel rail, if the 5.3 L is a 1999 - 2003 it would have came with a return style fuel rail - this could also be adjusted.
    Can pretty much do anything you want ... just takes time and money.
    Regards,
    Taz
    If your harness is setup for a truck tune, then leave it be and run a truck OS. I wouldnt buy another PCM just to get the tune from it, better off seeing if someone can post the tune for you or if you could pay someone a few bucks for it.
    And dang it! My buddy has an 01 Silvy with the 4.8L and a manual, but I havent read the tune from it! Ill text him tomorrow and figure out where he is, could be Spokane and I could get it this weekend or he could be back home in Alaska. It should be pretty easy to take a 4.8L manual tune, change the VE and volumetric settings to mirror the 5.3 and be done with it. Does anyone else have one of those tunes, should be pretty straightforward to adjust it for the 5.3.
    Apr 2012
    I'm happy to pay for that tune.
    I'm selling the engines here in the UK with the harnesses modified to standalone (3 wire hook-up), and nobody wants auto, as you'd expect here in the UK. Pretty much everything is LM7 5.3 FBC, and I'm doing about 6 a month so that tune will be seeing some use.
    Whilst I modify the harnesses myself and I have a Flashscan to remove vats etc etc, I have no interest in tuning beyond reflashing these ecms for the standalone use.
    Mar 2007
    So what happened in the end? I need the exact same tune setup for a rock crawler. its funny that its the same OS too.
    1972 Chevy Blazer, Twin Turbo Duramax 6.6
    69 Maro TT 427 LSX, Wayne due Vett frnt sub,
    Lateral Dynamics 3 link rear, D 60,
    T56, 18X10' 18X12 Boze Forged Speedsters,
    13" wilwood 6 pot fronts 13" wilwood 4 pot rears,
    (all Still under construction)
    Jul 2005
    Quote Originally Posted by Madspeed View Post
    Get ahold of Taz. He has what you desire. Perhaps a Private Message?
    peace
    Hog
    Jul 2005
    Quote Originally Posted by Taz View Post
    OK ... do you have a 512 Kb LS1-B PCM or a 1 Mb LS1-B PCM ? Are you using a DBC or DBW setup ? Does your wiring harness have Blue / Red PCM connectors, or Blue / Green PCM connectors.
    Again, difficult to assist without more information.
    For reference tunes - check out the www.tunefiledepot.com
    Regards,
    Taz
    That website is NO MORE. EFILive is cutting back.
    peace
    Hog
    Diesel Forum Support Site Admin
    Nov 2005
    Quote Originally Posted by hog View Post
    peace
    Hog
    You're referencing a 4 year old post. EFILive never owned or managed tune file depot, but the owner has taken it down.
    You'll find links to other resources using the search feature.
    Cindy
    Sent from my iPad using Tapatalk
  9. #19
    The resources from the original site (which was owned by a third party) have been moved to another site (which is owned by a fourth party), see here:
    Tunefiledepot-has-been-replaced
  1. auto to manual e38
    By dags in forum Gen IV V8 Specific
    Last Post: March 6th, 2010, 09:18 AM
  2. Conversion of Auto to manual.
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 18th, 2009, 09:58 AM
  3. auto calibrations for manual?
    By BackinBlack02SS in forum Gen III V8 Specific
    Last Post: December 2nd, 2008, 02:08 PM
  4. V4 License auto or manual
    By leibhold in forum Purchase and Shipping
    Last Post: November 26th, 2008, 05:54 PM
  5. camaro auto to manual conversion
    Last Post: March 26th, 2007, 12:15 AM
