Results 1 to 3 of 3
Thread: After start up idle drop
    Senior Member Naf's Avatar
    Aug 2006
    Default After start up idle drop
    I have upgraded my MAF from the stock tube to a 102mm, using the same sensor. I have calibrated the sensor to be perfect and the truck starts up with no a/c perfectly. If and when i start up with the A/C on the truck will start up, rev to about 1250rpm, steadily drop to 1000rpm then rapidly drop to just about 400rpm, it will then recover by over revvin to 1500rpm and settlin at the desired idle speed.
    I checked the WB and it showes 8 afr at startup, then 14.6 afr after startup then 9 afr during the sudden rpm drop. and back up to 14.6 afr durin the constant idle time.
    Its my work truck and loggin the data with a WB take a while, and i apologize for this.
    Does anyone know why this is happenin?
    American Muscle, European Design, Japanese Tactics
    Aug 2006
    Quote Originally Posted by Naf View Post
    Here is a log minus the Wb...
    Aug 2006
    Found out what my problem was...
    I tuned the MAF with an open loop ben factor to be around the currect afr value. so i was gettin the amount of air the MAF was registerin.
    If you have a uncalibrated MAF follow the idle instructions, However, if you took the time and calibrated properly, then you may return all your idle settings to stock, or close to stock...
    I am runnin a 226/236 cam and 550lift at the valves. Idle settins are stock and it loops just the same as it did with the restricted idle settings. But i can start the truck remotely with the AC on and it will not dye after initial start, and it also doesnt surge when i am stuck in traffic
  1. what could cause idle to drop low and not shoot back to normal
    By Crunkmaro in forum Gen III V8 Specific
    Last Post: December 24th, 2011, 10:25 AM
  2. Rich at start up, and in idle
    By Naf in forum Gen III V8 Specific
    Last Post: January 17th, 2010, 09:01 AM
  3. B4317 to drop idle faster when coming to a stop?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: August 4th, 2009, 06:53 AM
  4. Cold start great but warm start sucks."Idle
    Last Post: October 26th, 2008, 12:22 AM
  5. High idle on start up..
    By dirt_track_racer_81 in forum Gen III V8 Specific
    Last Post: April 27th, 2007, 05:12 AM
Tags for this Thread
