Results 1 to 10 of 16
Thread: FlashScan Commercial Licenses
    Default FlashScan Commercial Licenses
    If you have upgraded to an EFLive Commercial license, the following screen shots show the various authorization levels that the EFILive Tuning Tool software will use.
    The first image shows what you will see in the Help->About window if you DO NOT have your FlashScan cable plugged in BEFORE the software is started AND you have not entered your EFILive license details into the Help->Register EFILive window correctly.
    The second image shows what you will see in the Help->About window if DO NOT have your FlashScan cable plugged in BEFORE the software is started BUT you have entered your EFILive license details into the Help->Register EFILive window correctly.
    The third image shows what you will see in the Help->About window if you DO have your FlashScan cable plugged in BEFORE the software is started REGARDLESS of whether you have entered your EFILive license details into the Help->Register EFILive window correctly or not.
Name:	FlashScan License 1.jpg
ID:	458   Click image for larger version.
Name:	FlashScan License 2.jpg
ID:	459   Click image for larger version.
Name:	FlashScan License 3.jpg
    Lifetime Member MN C5's Avatar
    Mar 2005
    Paul, I'm having a hard time seeing any difference between the images..
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Quote Originally Posted by MN C5
    You will see in the middle "License". Here in each of the pictures you can tell what it is set to. Demo, Personal, Commerical.
    I have updated the images to highlight the differences.
    Mar 2005
    duh, I've now got my reading glasses by the computer.
    This should be a sticky.
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Mine shows the first image
    Without the cable it defaults to demo mode
    It seems to work fine with the cable connected.
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Member bK's Avatar
    Mar 2004
    Quote Originally Posted by Beer99C5
    I had a similar problem, it would show demo mode after I had registered EFILIVE and the cable wasn't plugged.
    I double checked my rego codes and noticed my "ISSUE DATE" was wrong, that made all the difference, no more DEMO mode warnings when I start EFILIVE without the cable plugged in.
    Chassis by Holden
    Engine by Chev
    PCM modified by Flashscan
    Cam by Comp Cams
    May 2008
    Mine does the same thing and it never used to on the computer (that died) before I loaded everything on. Now on this new computer it switches back to demo mode without the cable plugged in and I cannot get it fixed it is dam annoying!!!!
    Did you re-enter the info from the blue license card...?
  1. V1 and licenses on 98 ECU?
    By LibertySyclone in forum FlashScan V1
    Last Post: December 11th, 2012, 02:36 AM
  2. V1 Commercial to V2 Commercial Upgrade
    By ls698ta in forum FlashScan V1
    Last Post: November 29th, 2010, 08:25 AM
  3. FlashScan V2 Licenses
    By 01 Hawk in forum Purchase and Shipping
    Last Post: January 13th, 2010, 02:33 PM
  4. VIN Licenses
    By schuter in forum Purchase and Shipping
    Last Post: March 18th, 2008, 09:59 AM
  5. can you still buy V1 licenses after upgrading to V2?
    By kp in forum Purchase and Shipping
    Last Post: March 19th, 2007, 09:23 AM
