Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Can't find some pids for VET tuning
    Jul 2008
    Default Can't find some pids for VET tuning
    I was selecting pids and when I got to the selection "tuning" section of pids its not in the drop down menu and manually looking for the pids such as CALC.LTFTBEN I cant find them. I copied the Calc pids text file over to the configuration folder (also changed to match my analog WB) as I thought I should have. was there more to it than just moving it into the folder?
    Jul 2008
    humm tried again and now they are there. however I dont think I understand what to copy in for the narrow band
    Can you post your calc_pids.txt file.
    Quote Originally Posted by myws6formula View Post
    ... however I dont think I understand what to copy in for the narrow band
    Copy to where (can you give me more context)...?
    Jul 2008
    calc_pids.txt
    under CLC-00-110 I pasted {GM.EQIVRATIO}*({CALC.AFR_LC11}/14.7) over the original formula
    then I changed the description to "BEN from Analog WB" thinking that was the reason but that didn't work.
    actually after the final change I got an error opening the scan tool up so I reverted back.
    Ok, I fixed up your calc_pids.txt (the closing quote " on CLC-00-110 had fallen onto the next line), see attached, please try this.
    Jul 2008
    Thank you ! that did the trick.
    Jul 2008
    I haven't had a chance to do any logs yet but I was wondering a couple things... 1st do I have to disable the MAF or MAP when logging?
    I thought the point of this was that you didn't have to do anything other than log and take the average from each map when done with a 45-60 min log
    2nd question is since I have a Road Runner can I set it up for this for real time tuning? it would seem I could only run one map at a time though
    With Calc.VET you can leave the VE enabled because the transient filter throws away any contribution from the VE
    [ Calc.VET corrects the MAF, this requires all the airmass to come from the MAF only;
    MAF is used exclusively above 4000 rpm and during steady state below 4000 rpm;
    so when you apply the transient filter it removes transient data (where the VE was used), so only the MAF data remains ]
    Yes, you could use the RoadRunner to correct the MAF using Calc.VET... I haven't done this yet, you would have to study the RoadRunner subforum;
    the calculated VE table could be applied from a log taken later after the MAF was corrected...
    ( or you could disable the MAF and use the RoadRunner to correct the VE )
    if you're going to correct the MAF using Calc.VET with the RoadRunner, then I would recommend disabling the VE first (set B0120 to zero).
    Jul 2008
    ok thanks.
    would almost seem as thought its faster / simple not to use the road runner. unless you could open both the maf and ve table at the same time.
  1. WOT Issues tuning with Calc.VET
    By Crisses in forum Gen III V8 Specific
    Last Post: November 22nd, 2011, 06:09 AM
  2. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
  3. which pids for ve tuning w o2s
    By ssmike300 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 1st, 2008, 11:52 PM
  4. Idle Tuning Thread (help me find it)
    Last Post: October 2nd, 2007, 06:42 AM
  5. Porsche 996 TT tuning software?? Where to find...Bosch ME7.8 PCM
    Last Post: April 27th, 2007, 01:51 PM
