Results 1 to 8 of 8
Thread: Injector Dynamics "ID 850" Help!!! Question...
    Aug 2008
    Question Injector Dynamics "ID 850" Help!!! Question...
    These injectors are 80lb injectors and I knew I had to scale the tune in order to make them work... I took my time and scaled everything that i thought needed to be scaled and did it by 50%.
    And no matter what I did, the motor would flood while cranking!!! The pressure was at 58psi, I had good voltage and spark...new spark plugs and injectors were wired correctly. If I disconnected fuel pump relay, motor would fire right up and idle for 1-2 minutes with no fuel pressure!!!
    I worked on that motor for 6 hours and could not figure out what was happening so I gave up...
    So this morning with a nice big cup of coffee I started to go thru the whole tune and found one really big mistake. I thought I had my units in grams/second and I actually had them in lb's/hour. My question is would this cause massive overflooding even though I accidentally had 6lb injectors in the Tune instead of 40lb injector's???
    HAD---- NEEDED
    6.198--- 49.190000
    6.237--- 49.500000
    6.275--- 49.800000
    6.313--- 50.100000
    6.350--- 50.400000
    6.387--- 50.690000
    6.423--- 50.980000
    6.459--- 51.260000
    6.494--- 51.540000
    6.529--- 51.820000
    6.564--- 52.090000
    6.598--- 52.370000
    6.632--- 52.630000
    6.666--- 52.900000
    6.699--- 53.170000
    6.732--- 53.430000
    6.766--- 53.690000
    FLASHSCAN V2 & AUTOCAL
    Apr 2009
    YES. If the ECU thinks that the injector is only flowing at a rate of 6lb/hr, then it will need that much more on-time in order to deliver the target fuel mass. This new (longer) pulsewidth that accommodates the supposedly low flow rate actually delivers a LOT of fuel when you have ID850's in there...
    ~Greg
    Calibrated Success - EFI Training and Tuning Done Right
    GM Beginner's Guide DVD available now through Summit!
    Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
    Aug 2008
    Alrighty, I still can't believe I messed that up...:-D
    You will need to change your oil before running your engine again...
    Jul 2007
    BTW, Injector Dynamics have excellent support for EFILive in their data page. They provide an Excel spread sheet with all the required table data to suit their injectors. It makes tuning very easy when you don;t need to guess a lot of the settings.
    Simon,
    Aug 2008
    Simon,
    I agree, it's just that when I copied and pasted the Injector Flow rate from the ID spreadsheet I went directly to the gram's/second column not realizing I had my tune file in lb's/hour....
    Aug 2008
    If I scaled the tune by 50% and I'm working on my VE table, when I'm doing the copy-paste and multiply, Do I have to do that by 50% also???
    Jul 2007
    I'm assuming this is for the Auto VE process? If so, then the adjustments should be 1:1. This is because you are referencing MAP and RPM, neither of which have been scaled. You still want to get the VE "correct" for the scaled injector settings, so the correction factor does not change. So a normal paste and multiply process, don't reduce the correction factor.
    Simon
  1. "File Sys FULL!" followed by "ERROR: $0520"
    By Sushisan in forum AutoCal
    Last Post: April 24th, 2012, 06:35 AM
  2. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  4. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
  5. Tip/trick For The "big" Injector Guys!
    Last Post: August 15th, 2006, 02:52 PM
