Results 1 to 8 of 8
Thread: error code $0502
    May 2012
    Default error code $0502
    I just received my Auto-Cal and after installing the software successfully I went to read the stock tune in my 97 Vette. After following the hook up instructions I scrolled down to read and hit ok. I got an error code $0502, does anyone know what that is? If anyone does what is the procedure to get rid of it so I can read my stock tune? Any help would be appreciated.
    $0502 = script file not found;
    Do you have V7 build 204 and V8 build 195 installed...?
    Does your AC have firmware 2.07.27 installed...?
    Did you do this: start V8 S&T, goto BBx, goto Tuning, configure which ECM/TCM you're interested in, do Program All (down arrow next to Program button)...?
    May 2012
    I have V8 build 195 installed, should I also install V7 204?
    I have firmware 2.07.28 installed
    Didn't do the third item but then again I don't know how to.
    Thanks for responding
    Ah, I meant builds 205/196 and firmware 2.7.28
    You need V7 only if you're viewing log/tune files.
    Start the V8 Scan and Tune (S&T) software, click BBx, click Tune, create an entry for your ECM or TCM, or use the existing one, delete all others that do not pertain to you, click Save, click the down arrow next to Program, click Program All.
    May 2012
    Thanks will give that a try
    Now there is builds 206/197...
    install those (skip V7 if you don't need to view logs/tunes) and then do this:
    May 2012
    Thanks I did what you said and it took my stock readings. Thanks for all your help could not of done it without you.
    No worries.
  1. Error $0502
    By Webbs in forum AutoCal
    Last Post: December 9th, 2016, 06:31 AM
  2. Error $0502
    By Gregs in forum FlashScan V2
    Last Post: February 20th, 2012, 08:49 AM
  3. $0502 Error when attempting BBR on CMB849
    By vortecfcar in forum AutoCal
    Last Post: June 10th, 2011, 05:56 AM
  4. Can't BBX full flash (Error $0502, script file not found)
    By spandit in forum FlashScan V2 BB Logging
    Last Post: April 14th, 2011, 08:34 AM
  5. Error $0502 Script file not found
    By jcow in forum Allison 5 & 6 Speed
    Last Post: April 14th, 2011, 12:53 AM
